SolaraGuy.com • View topic - shaking front end on 2002 solara
Postby mika » Tue May 08, 2007 5:34 pm
what do u do about a 2002 sloara that shakes on the free way?
i just boought one and i wanna make it run clean ....
thanx
mika
Postby woa_its_j3ff » Tue May 08, 2007 5:37 pm
are your rotors warped?
Postby sahuddleston » Tue May 08, 2007 5:42 pm
is it when you are braking or just cruising? does the steering wheel shake and vibrate in your hands while you are driving? give us some more info on exactly what is happening.
2012 Ford Shelby GT500
2013 Hyundai Genesis 4.6
sahuddleston
Postby mika » Tue May 08, 2007 5:43 pm
i dont think it the rotors cause it shakes accelerating not braking..
from like 50 up it develops a slight shake i replaced the tires too[/b]
mika
Postby mika » Tue May 08, 2007 5:45 pm
i can feel a slight vibration in the gas pedal and the steering wheel........
could it be the suspension?
mika
Postby woa_its_j3ff » Tue May 08, 2007 5:52 pm
deleted.
Postby Biggi_e » Tue May 08, 2007 6:42 pm
get your alignment checked out or your wheels arent balanced properly.
Postby Yanks0114 » Tue May 08, 2007 10:26 pm
Any reason this is in the suggestions forum?
I guess you're looking for "suggestions" but this should be in the gen 1/1.5 section
Postby (K) » Wed May 09, 2007 10:52 pm
It probably IS your wheels. Nothing TOO serious, did you buy it from a toyota dealership?
Just get them balanced.
(K)
Postby bassthrive » Thu May 10, 2007 8:52 am
4 wheel alignment and a wheel balancing should fix it.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby anttarz » Thu May 10, 2007 9:30 am
wheel alignment - corrects direction of tires
balancing - corrects vibration in wheels
def get em aligned and balanced
-smooth ride
-save gas
-even tire wear
anttarz
Postby theprodigy79 » Thu May 10, 2007 9:38 am
Also have your wheels checked out for bends or warping... Have you hit any curbs or pot holes recently?
theprodigy79
Postby mika » Thu May 10, 2007 6:07 pm
i tried all that ......no help...........thanx for the replys...this seems like a suspension probllem.........could it be from bent shocks or struts?
mika
