SolaraGuy.com • View topic - changing tranny fluid
Postby TMMK Toy » Sun May 13, 2007 9:11 am
Figured I'd post this in here since this is viewed more than the camry forum and applies to both our cars. On the e153, what's a good transmission fluid to go with? I was thinking redline but just wanted to make sure that that was acceptable to use. What I used on the t50 in my ae86
TMMK Toy
Postby unbalancedwood » Sun May 13, 2007 9:19 am
I mean, the best seems to be royal purple or redline, of course the most expensive ones. If you do decide to go with one of those i think what recommended is a flush of all 12qts and a refill of the new 12qts...(well that is with the solara at least)
unbalancedwood
Postby TMMK Toy » Sun May 13, 2007 11:15 am
12 qts? wtf are you smoking? Its a manual, holds I bet no more than 3 or so. Even an automatic camry/solara prob. doesnt hold much more than 5 quarts of atf if that
TMMK Toy
Postby crispone » Sun May 13, 2007 12:39 pm
TMMK Toy wrote:12 qts? wtf are you smoking? Its a manual, holds I bet no more than 3 or so. Even an automatic camry/solara prob. doesnt hold much more than 5 quarts of atf if that
I IN-LINE FLUSHED my tranny ('04 V6 SE Sport A/T) with 10 (TEN) quarts of the recommended ATF from Toyota. (I'll use AMSOIL next time...)
It only "requires" 5 or so if you just "drain-n-fill", but you want to FLUSH THE SYSTEM clean, or it's a half-arse-job...
WORKED GREAT!
...FWIW...
Postby TMMK Toy » Sun May 13, 2007 3:54 pm
Ok anyway I'm talking about the e153 so ya, just gathering opinions on redline and also would be good to know the capacity I suppose.
TMMK Toy
Postby TMMK Toy » Wed May 16, 2007 2:49 pm
bump. capacity and options on redline on the e153?
TMMK Toy
Postby unbalancedwood » Wed May 16, 2007 4:21 pm
Here you go, and ps, i wasent smoking anything...at the time.
Hopefully this is what you wanted, cause i still dont fully understand. Do you have a camry or mr2, with a different engine or what...?
Heres the main page
http://mr2.noegruts.com/trannyoil/trannyoil.htm
unbalancedwood
Postby TMMK Toy » Wed May 16, 2007 7:52 pm
Thanks man. I got a 99 camry with a 1mz and an e153. At 64k so want to change the tranny fluid
TMMK Toy
Postby CASTRO » Wed May 16, 2007 11:53 pm
hahah, looks like no one knows what an e153 is. Guys, that is the 5speed and NOT auto transmission. It is used on the Camry/Solara/MR2 manuals. It does NOT use the same amount as our autos as it does not need to fill a torque converter or lube all those clutches.
Man, if only I could find my haynes manual, i'd post up how much fluid you'd need to put in. But, I do have a solution that was once discussed by a few of the old guys long gone from this site.
GM Synchomesh.
Sounds crazy but almost all the old members swore that it took care of the grinding and manual transmission problems the've been having. An old discussion of a person here who did a manual swap was unlucky and got a worn tranny. Having the swap done, he wanted to keep it in there but wanted a quick and simple fix. Tried all the fluids, but seemed that the GM stuff did the trick. Hope that helps.
CASTRO
Postby Midias » Thu May 17, 2007 10:57 am
I think it was 4.2 I know it was between 4 and 5 quarts and I think you7 use 75w-90. I used mobil 1. So get 5 quarts and fill till it runs out of the filler plug.
Postby bronzemaxell » Thu May 17, 2007 12:15 pm
according to dealer service manual,
it is 4.4 US Qt for E153 manual transmission,
2.7US QT for 4 cylinder camry manual transmission
doesn't hurt to buy 1 bottle extra incase there is spill
bronzemaxell
Users browsing this forum: Google [Bot] and 9 guests
