SolaraGuy.com • View topic - Stock head unit with sub-amp??? anyone?
Postby mailskobe » Mon Apr 14, 2003 9:28 pm
Does anyone have the configuration as above.
has anyone interfaced a sub-amp with a stock solara head unit.
thanks
mailskobe
2000 SZ V6, 5 speed, silver
mailskobe
Re: Stock head unit with sub-amp??? anyone?
Postby impactX » Mon Apr 14, 2003 10:18 pm
mailskobe wrote:Does anyone have the configuration as above.
thanks
mailskobe
Get a subwoofer amp with speaker level input and tab those into the rear 6x9s.
impactX
Postby mailskobe » Mon Apr 14, 2003 10:24 pm
have those, jbl600.1 to rear speaker highlevel outputs.
dont like the SQ too much! :(
mailskobe
Postby impactX » Tue Apr 15, 2003 8:30 pm
Then you will probably need a new deck.
impactX
Postby Turbosolara » Tue Apr 15, 2003 11:06 pm
you need to buy a output convertor and tap it behide hedunit with cutting factory speaker wires. It will convert the voltage to low voltage so that your aftermarket amp will do the work.
Postby swimshady906 » Wed Apr 16, 2003 5:58 am
ultraslow is right.. for the best sound quality if u dont want to replace your h/u then the converter is best... any amp's high level input has a much higher THD compared to the RCA's .. i would jsut get a new h/u .. i mean you will get better control over your sound with just about anything u buy :D
02' S2000 Silverstone
swimshady906
Postby kubi » Wed Apr 16, 2003 6:46 am
UltraslowSolara wrote:you need to buy a output convertor and tap it behide hedunit with cutting factory speaker wires. It will convert the voltage to low voltage so that your aftermarket amp will do the work.
Have you actually ever done this on a Solara, though? I tried using a line converter on my stock headunit while I was waiting for my MP3 player, and it worked.... but you couldn't really hear it. If you opened the trunk you could tell the subs were hitting, or if you were sitting in the back seat, but thats it... And I'm pushin 2 Kicker L7's off of a 2400 watt class D amp. I took it to a shop who couldn't get it to work, either, so I just gave up and waited 2 weeks for my head unit.
The best I could come up with was.... either the head unit just won't work with a line converter for some reason, or... Some Toyotas come with a built in amplifier for your components, however I'm not sure if the Solara does or not. You would probably have to bypass that amp if you wanted it to work. (assuming it actually exists, the headunit may just be worthless :roll: )
kubi
Postby mailskobe » Wed Apr 16, 2003 11:14 am
first off, i have a JBL premium, so my car has an amp to drive my car speakers. so, in my case, my head unit gives out low level output.
i cant tap those outputs and feed it to a high-low converter.
i will have to tap the high level output of my stock amp, then feed it to a high-low convertor and the feed the RCA output of my high-low to RCA input of my sub-amp
<b>Another q, i ran power cable thru the firewall like others have done, thru the right side and it causes interference with my radio, FM channels. anyone noticed that before?</b>
thanks,
mailskobe
mailskobe
