SolaraGuy.com • View topic - Wheel vibrates a lot
Postby rec » Wed May 16, 2007 2:33 pm
When i drive on the freeway my steering wheel vibrates alot because of my tire. Ive had my front tires balanced twice already and it still didnt solve the problem only for a lil bit then it starts back up again. I know i need a alignment so could that be it ?
Mine is black.......
rec
Postby SolaraBlue » Wed May 16, 2007 2:36 pm
if you need an alignment then YES thats your problem! align all 4 wheels and and make sure all 4 tires a balanced.
Postby SleeperSolara » Thu May 17, 2007 6:32 pm
The rear rims are not balanced......
Make sure all the rims are all balanced, and aligned.
Postby QuickSEV6 » Thu May 17, 2007 7:16 pm
^^^ These guys are right.
More than likely, your wheels are out of balance. Generally, if it were an alignment issue, your car would pull to one side when driving.
Get your tires balanced and you should be ok.
Postby woa_its_j3ff » Thu May 17, 2007 7:20 pm
why only just front wheels balanced?
things are better when on all fours :drinking: HA. jk.
so balance the wheels -- should be good after that :)
Postby 1gSE » Thu May 17, 2007 8:24 pm
make sure the shop isn't doing a static balance (tape weight in the center of the wheel) You might have thrown a weight. Have them check for high spots on the tire while it's being balanced. If it's takin alot of weight in one spot, they should turn the tire 180 degress on the wheel
Solara-M62 @ 5.5psi
1gSE
Postby TadS » Fri May 18, 2007 6:11 am
Check the tires for cupping, and broken belts. Even a well balanced tire will vibrate if it's cupped. Also, get the front end checked out, although it's probably just a wheel / tire issue. To trouble shoot it yourself, rotate the tires front to back. If the vibration changes, then you know that the problem is in the wheels / tires. If you know you need an alignment, get it done, as bad alignment = ruined tires.
TadS
Postby rec » Fri May 18, 2007 8:41 am
well i got the alignment and it made my steering a lot better. More control then before i think. My steering wheel still shakes a lil bit when driving at 80 mphs but i was thinking mayb its because it has 18" rims ? and the ground is screwed up
rec
Postby SolaraBlue » Fri May 18, 2007 8:54 am
^^^ do you have hub rings for your wheels? if not, they could make a nice difference.....
Postby Sentinel » Fri May 18, 2007 11:16 am
If you have old tires then they can get out of round. Especially if you had them on the rear of your FWD for too long. Balancing will not help this.
Sentinel
Postby offthahook » Fri May 18, 2007 1:02 pm
I had the exact same problem! It turned out one of my rims was slightly cracked on the inside of the wheel. No amount of balanceing will fix that. I think it is about $80 to weld a rim. Even a hairline crack will cause vibration of the steering wheel.
offthahook
Postby mcmullin77 » Fri May 18, 2007 2:45 pm
i am currently having the same issues. i just put brand new 18' rims and tires on my car. i had it in the shop two days ago trying to figure out what was going on. all four tires are balances and there is no pull to either side.. they said it could and probubly is just the road. most roads have the smallest little heaves that you pretty much need to be laying on the road too see them. and with a low profile tire or one with not much tread it will pick it up and cause vibration in you wheel.
mcmullin77
Postby uha1 » Sat May 19, 2007 9:33 pm
I had the same problem with my previous car. It was a honda accord. Even though I got it balanced it didnt solve the problem. Than it turned out to be the rotors. see if the car vibrates when you brake.
uha1
Postby mcmullin77 » Sun May 20, 2007 2:35 am
hahaha once again i just put 4 brand new rotors on.. they did vibrate a little when i put the breaks on so thinking it was that i went and put new ones on.. problem still on going and its driving me nuts.
mcmullin77
