SolaraGuy.com • View topic - Cleaning Engine Bay: How do I remove this?
Postby CamryOnBronze » Fri May 25, 2007 5:01 pm
okay, so here is the deal. I have only had the car for about 2k miles. Something blew up at some point in the passenger side of the engine bay near the power steering fluid and coolant reservoirs. It is caked on and stuck in there pretty good, not something simple green and a powerwashing will remove, so I know it isnt recent and isnt leaking at the moment. I think when they replaced whatever broke they didnt clean up what had spilled... bummer.
There is a box right by the washer fluid fill with steel lines coming out of it with bosch markings on it. Im guessing it has something to do with ABS... but Im not positive what it is for. I know I cant exactly remove this all of the way from the bay (I dont think) but is there a way to pick it up a couple of inches so I can clean under it? How would I go about removing it if I wanted to? I removed both reservoir tanks over there and cleaned under them just fine.
There are two bolts in the side of it- I removed those and tried pulling up on the whole unit, but it wasnt moving much. I dont want to damage anything so I thought I would ask how to remove it. Thanks to anyone with ideas:
Damon
Postby Midias » Fri May 25, 2007 5:25 pm
Try simple green and fill your coolant
Postby CamryOnBronze » Fri May 25, 2007 5:42 pm
1. I know to fill my coolant, just didnt do it yet.
2. Did you read my post? I already tried simple green, this stuff really needs to be scrubbed.
Postby DatSRBoi » Fri May 25, 2007 6:09 pm
Its been awhile since I touch that but either theres a bolt under it or theres a slid under it that you just slide the unit over. I wouldnt touch it because if one wire or line snap, Your going to have a big bill. Just use engine degresser.
Postby CamryOnBronze » Fri May 25, 2007 7:08 pm
Im going to try degreaser again, but I have been spraying it all day and this is not going to come off without scrubbing and I cant scrub because I cant get to it... I guess Ill work around it, thanks anyway guys...
Suggestion
Postby JMSinMaryland » Fri May 25, 2007 7:12 pm
It's always easier to clean if you know what you're cleaning. Find out first, then clean. Toyota used to use black blinker fluid before 2002, there was a TSB to flush out the old fluid and replace with clear fluid. Jon. btw cars that haven't been taken back will have blackish turn signal lights and headlights, similar to how yours looks.
JMSinMaryland
Postby CamryOnBronze » Fri May 25, 2007 8:04 pm
awesome, thanks...
Postby PhreakdOut » Fri May 25, 2007 10:22 pm
^^ WTF Jon? That was helpful.
Damon, keep using degreaser / simple green and a toilet brush. You may need to cut the loop on the toilet brush so it's like a long pipe cleaner attached to a stick. The brissels are not too strong to scratch up the paint but strong enough to work the gunk off. If needed, loosen the accumulator and lift up slightly. Zip tie it up if you need but as said before, watch the lines. Have fun, I'll take a look at it at the next meet.
Postby NeFaRiOuS_SLE » Fri May 25, 2007 10:46 pm
Is it the brown gunk to the left of the ABS solenoid, and what exactly blew so that we can offer something more... Insightful?
Postby CamryOnBronze » Fri May 25, 2007 11:35 pm
Yes its the brown gunk, I got a ton of it off before I took that pic. I just kept dousing it over and over and its finally starting to break down, so I think Ive got it now.
I have no idea what blew, like I said it wasnt when I owned the car, it was the previous owner... Im no noob to cars or cleaning engine baysand I dont really care what was leaking because it is fixed and isnt leaking anymore, I was simply looking to see if anyone knew how to remove the abs actuator so I could clean under it, thats it... thanks.
Postby hskrsolara » Fri May 25, 2007 11:45 pm
dont worry about jon...sometimes he has his moments... :roll:
hskrsolara
Postby CamryOnBronze » Fri May 25, 2007 11:46 pm
its cool haha, solaraguy seems to be more a database for supercharger info and occasionally a good for sale database to me at this point, but it sure isnt much help beyond that :lol:
Postby JMSinMaryland » Sat May 26, 2007 3:35 am
hskrsolara wrote:dont worry about jon...sometimes he has his moments... :roll:
JMSinMaryland
