SolaraGuy.com • View topic - Check Engine light just came on
Postby black99 » Mon May 28, 2007 10:51 pm
My Check Engine light just came on the other day, so I took it to Advanced Auto Parts to check the code. It reads P0446: EVAP Emission Control System Vent Circuit Malf. Does anyone know what this is or how easy it is to fix? Is it just an O2 sensor?
99 SLE auto- Tein/Tokico combo- TRD RSB- 20% tint all around- 50% windshield- custom grill- Alpine 9857- Alpine Type R comp's- Type S 6x9's- Alpine MRP-M1000- 2 JL Audio 12W3v2- "blacked out"
black99
Postby Nyyankees3511 » Tue May 29, 2007 4:45 pm
Check and make sure your gas cap is fully tight meaning at least 3 clicks. It could be your gas cap or the charcoal cannister. But start out with the cap and check for cracked or loose hoses. And make sure you reset the light by taking out the negative battery terminal for a couple of minutes.
Nyyankees3511
Postby Midias » Fri Jun 01, 2007 11:20 am
I would say No to it being your gas cap that is usually po441 what you have is either a bad charcoal canister or vsv valve on top of the charcoal canister both common problems. The vsv valve ran me about 220 and they told me about 370 if I had needed the canister.
Re: Check Engine light just came on
Postby Jai_Jai_Binks » Fri Jun 01, 2007 7:20 pm
black99 wrote:My Check Engine light just came on the other day, so I took it to Advanced Auto Parts to check the code. It reads P0446: EVAP Emission Control System Vent Circuit Malf. Does anyone know what this is or how easy it is to fix? Is it just an O2 sensor?
If this is the first time your CEL is on, i wouldnt worry too much about it, unless it becomes something that doesn't turn off. My cel came on and well I popped a similar question - esp since it went away when i parked the car. It happened to do be something with my battery?? (go figure).
Postby Sentinel » Fri Jun 01, 2007 8:44 pm
open or short in VSV (vacuum switching valve) circuit for EVAP, or the VSV valve itself
open / short in vapor pressure sensor circuit, or the vapor pressure sensor itself
open or short in VSV (vacuum switching valve) circuit for vapor pressure sensor, or the VSV valve itself
vacuum hose
charcoal cannister
isbn 1 56392 404 8 :Haynes manual: Camry 97-2001, includes Avalon, Solara and Lexus ES300 <hint hint>
Sentinel
