SolaraGuy.com • View topic - quick wheel question
Postby offroadinfrontier » Thu May 31, 2007 10:49 pm
not necessarily gen 1 specific i guess, but a quick question on wheel sizes (i don't really understand the measurements):
can a 205/60-16 tire fit on a rim that currently has a 195/60-16 tire on it? i know the 205 tire can fit on rims betw. 5.5-7.5, which should be in range of the rims the smaller tires are on, but i dont know the exact size of the smaller rims (or what the 205/195 are measuring). thanks!
offroadinfrontier
Postby WTF?? » Fri Jun 01, 2007 12:01 am
quick answer: yes
be sure to do both fronts or both rears or all four
do not just change ONE single tire with a different size and/or brand for that matter
This should also help you: http://www.solaraguy.org/viewtopic.php?t=25804
Retired... its been fun Image
WTF??
Postby offroadinfrontier » Fri Jun 01, 2007 11:21 am
thanks. i curently have the stock 16" with some really nice tires i just bought, but due to some trouble im going to be switching to slightly smaller rims, and dont want to get rid of these brand new tires.
offroadinfrontier
Postby **PoshPepper** » Fri Jun 01, 2007 11:30 am
What smaller size are you going to? The stock 16s are already small
The Original... SOcalLARA
Milt's OTHER ride
**PoshPepper**
Postby Sebas007 » Fri Jun 01, 2007 1:13 pm
convert your tire width in inches
25.4 is the magic number to convert mm to inch.
To make it even more clear : 25.4mm = 1 inch
205mm / 25.4 = 8.07 inches then you can see if your rim is wide enough or not.
Postby offroadinfrontier » Fri Jun 01, 2007 10:09 pm
the new rims are 16", but slightly skinnier. not sure the exact specs yet
offroadinfrontier
