SolaraGuy.com • View topic - Where to buy a knock sensor?
Postby Sleeper » Fri Jun 01, 2007 9:27 am
I blew my knock sensor some time ago and I am now looking to purchase another one. Does anyone know of a place that sells knock sensors either online or in So. Cal. for a good price? Thanks. How much should they usually run for, price wise?
SLEEPER...
Sparco Torino Seats, TRD Blower, Autometer Boost, Air/Fuel, and Tach gauges, DVD Touchscreen receiver, Carbon Fiber Reverse Gauges/Hood, 8K HIDs, Complete TRD Suspension, SPEC Stage 3 clutch & flywheel
Sleeper
Re: Where to buy a knock sensor?
Postby Dawgz » Fri Jun 01, 2007 9:49 am
Sleeper wrote:I blew my knock sensor some time ago and I am now looking to purchase another one. Does anyone know of a place that sells knock sensors either online or in So. Cal. for a good price? Thanks. How much should they usually run for, price wise?
Sorry to be offtopic here but i just have a question, what psi are u boosting at and do u have Jim's Fuel mod?
Postby Sleeper » Fri Jun 01, 2007 9:53 am
im boosting 4.5 psi with a 2 3/4 high flow cat and safc. No i dont have Jims fuel mod. how come?
SLEEPER...
Sleeper
Postby Eye8Pussies » Fri Jun 01, 2007 10:45 am
because without the fuel mod, your front bank is running lean, leading to the knocking and the blowing of your sensor
even if you just replace it now, you'll just end up blowing another one
for you guys without a return-style fuel setup, jim's fuel mod is pretty much a must to get fuel to the front rail
as for your question, the dealership and ebay. or a junkyard if you can find an engine that hasn't been torn apart
when I checked autozone, napa, etc back in the day, they wanted more for knocksensors than even the dealer did
Postby Sleeper » Fri Jun 01, 2007 10:57 am
How do i go about getting Jim's Fuel mod?
SLEEPER...
Sleeper
Postby ---CAMRAZY--- » Fri Jun 01, 2007 11:04 am
How about relocating the knock sensor, Ben?
Postby Astro » Fri Jun 01, 2007 12:08 pm
Sleeper wrote:How do i go about getting Jim's Fuel mod?
Check out his thread. His number is listed a few replies down.
Postby Sleeper » Fri Jun 01, 2007 12:23 pm
---CAMRAZY--- wrote:How about relocating the knock sensor, Ben?
you can do that? how?
SLEEPER...
Sleeper
Postby Sleeper » Fri Jun 01, 2007 12:26 pm
Would you have a link to his thread?
What's up with the dyno buuuuuuuuuuddy?
SLEEPER...
Sleeper
Postby Dawgz » Fri Jun 01, 2007 12:30 pm
http://www.solaraguy.org/viewtopic.php?t=32654
Jim @ Foreign Affairs
2315 SE 11th Avenue
Portland, Oregon 97214
503-236-2871
Postby ---CAMRAZY--- » Fri Jun 01, 2007 12:47 pm
http://www.toyotanation.com/forum/t157503.html
or
Eye8Pussies wrote:otherwise, you could also just rewire your single signal from one knocksensor into two and trick the ecu that way. you can either rewire it at the knocksensor side (be careful not to ground it improperly) or on the ecu side
2 people you can hit up, one is gLok over on TN, he is here also, but doesn't frequent as much..
http://www.toyotanation.com/forum/member.php?u=42
Or ask Eye8pussies over on TN, samething, he is here also, but not as much.
http://www.toyotanation.com/forum/member.php?u=1965
JoeB had done the GM sensors.
http://www.toyotanation.com/forum/t74791.html
Postby Sleeper » Fri Jun 01, 2007 12:49 pm
Thanks Milt. I guess knock sensors are more of a b!tch than i thought
SLEEPER...
Sleeper
Postby Astro » Fri Jun 01, 2007 5:07 pm
Oops, I forgot to post the thread :roll: Thanks, Dawgz!
Ben, I ordered the bored TB, so I'm going to wait for that which I hope will be soon because I really want to get on the dyno!!!
