SolaraGuy.com • View topic - CAR RUNNING TOO LEAN
Postby agent007 » Tue Jun 05, 2007 9:26 am
my car was reading too lean and misfiring, now just too lean. what are some of my options...ive replaced the a/f meter, spark plugs, wires, and 2 of 3 coil packs (one that was misfiring and a cracked plug one). what else could it be...any thing would help. cant remember the exact code but i looked it up in the mechanical book and it read system too lean...i no longer have my cai and went back to stock...only upgrade i have now is the greddy catback...??
01 solara v6 se
trd kit, trd rims, trd suspension
greddy evo cat back
c/f hood
agent007
Postby netherland24 » Tue Jun 05, 2007 9:48 am
check ur o2 sensor
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby agent007 » Tue Jun 05, 2007 10:55 am
yes that is an option but wouldnt the code have shot out with the CEL? i have replaced the one after the cat about 2 or 3 years ago but the code read the error... would that be the only other solution though?
01 solara v6 se
greddy evo cat back
c/f hood
agent007
Postby Eye8Pussies » Tue Jun 05, 2007 3:43 pm
a bad o2 sensor usually makes you run rich....
check for vacuum leaks
Postby agent007 » Wed Jun 06, 2007 8:28 am
okay...ill check for the leaks but think thats not the issue, how can i check the o2? is there anyway that i can check it with the multimeter or anything since im not getting a CEL?
thanks for all the help so far peeps.
01 solara v6 se
greddy evo cat back
c/f hood
agent007
Postby 19solara99 » Thu Jul 05, 2007 5:25 pm
if you go to a local auto parts store and buy a repair manual, it show's step by step how to check the 02 sensor. make sure your sensor is a 02 sensor and not a a/f sensor
19solara99
Postby agent007 » Mon Jul 09, 2007 11:51 am
i have the manual and i have replaced the both a/f sensors about a year ago and on o2 about 2 years ago...cleaned out the throttle and reset cpu and have driven my car for about 3 days now without CEl...will use injector cleaner on next fillup but seems that throttle was just too dirty and hopefully solved my ongoing problem...if not im just taking it to the dealor to mess with that or just shoot my car and bury it...does anyone know what else it may be ?
01 solara v6 se
greddy evo cat back
c/f hood
agent007
Postby Astro » Mon Jul 09, 2007 11:57 am
Could it be a clogged fuel filter? Maybe your just not getting enough fuel, when was the last time you replaced it?
Postby Turbosolara » Mon Jul 09, 2007 12:15 pm
post the code please
Postby agent007 » Mon Jul 09, 2007 1:20 pm
last replaced fuel filter about maybe 3 years ago...and the code was the SYSTEM TOO LEAN the one i think that is P0171 or P0174, i know it was the one fist too lean code in the book so the lowest # one, becasue there are a few that all refer back to one and it was just that one refered to...but like i said it hasnt turned on yet so could the cleaned throttle have helped...logically it could have but i was wondering what the alternative could be in worst case if the CEl turns back on
01 solara v6 se
greddy evo cat back
c/f hood
agent007
Postby dominoSLEV6 » Tue Jul 10, 2007 12:18 pm
Are you boosted or no? Any kind of tuning system on your car or stock ECU with bolton parts?
-chris
dominoSLEV6
Postby agent007 » Thu Jul 12, 2007 11:50 am
the only upgrade i have now it the Greddy exhaust and went back to stock intake when i replaced my a/f meter a few months ago
01 solara v6 se
greddy evo cat back
c/f hood
agent007
Postby SC V6 » Thu Jul 12, 2007 11:58 am
get some NA supra injectors (check the for sale section :)
SC V6
Postby xSolarax » Thu Jul 12, 2007 3:50 pm
I'm now having this same problem. Sorry if this is thread jacking at its best.
I just got my MAF replaced because I was getting P0171 and they diagnosed it as the MAF, this made the CEL change to SYSTEM TOO LEAN code. Anyone think of anything. I have a CP-E intake but I don't think that would make CEL appear since its "guaranteed".
also my Trac OFF gets tripped and stays on when the tires spin and my CEL is on.
I might also add that the CEL goes on one day and off another. THX in advance.
Gen 1 TRD Lip Kit, TRD RSB, TRD Struts, Tein S-tech, CP-E, CC, Kicker Comp
-->>PART OUT DECEMBER 10, 2008<<--
xSolarax
Postby agent007 » Fri Jul 13, 2007 11:41 am
i know that so many are far more exp than me but if i can help let me know...what upgrades...if you follow my post you can compare with your lara...clean the throttle body...i have had the CEL off for almost a week know and i just refilled the tank today with injector cleaner (really dont even know if this was necessary)...i really feel the cleansing of the TB did the trick...
01 solara v6 se
greddy evo cat back
c/f hood
agent007
