SolaraGuy.com • View topic - LED scanner help
LED scanner help
LED scanner help
Postby redgen1 » Fri Jun 08, 2007 1:37 pm
I bought one of those LED scanners last week after my car was broken into so i can at least make it look like more of an alarm system then stock - any one installed one before? finding the LED wire to the back of the gauges has proven rather tricky.
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby NeFaRiOuS_SLE » Sun Jun 10, 2007 7:40 pm
Dude... Just go out and get yourself an aftermarket alarm system; it'll be more worth it in the long run.
Re: LED scanner help
Postby krook » Mon Jun 11, 2007 2:55 pm
redgen1 wrote:I bought one of those LED scanners last week after my car was broken into so i can at least make it look like more of an alarm system then stock - any one installed one before? finding the LED wire to the back of the gauges has proven rather tricky.
if you bought a scanner with 3 wires (which they usually only come wired that way) the 3 wires should be: Red (12V), Black (ground), and Yellow (Ignition)
YOU CANNOT connect the scanner to and LED light. won't work. if you're hooking it up without an alarm, you need to connect those wires to each source respectively. that's the only way to do it WITHOUT an alarm.
krook
Postby redgen1 » Mon Jun 11, 2007 5:39 pm
yea.. i get that i want to hook it up to the alarm system and i have no idea how
02 SLE V6
redgen1
Postby krook » Mon Jun 11, 2007 7:41 pm
redgen1 wrote:yea.. i get that i want to hook it up to the alarm system and i have no idea how
that's the thing: you CAN'T.
unless you can find a wire for Toyota's OEM alarm that grounds when the alarm is turned on, you're gonna have to wire that Yellow wire from the scanner to ignition.
again, you can't connect a scanner and run it off a single LED.
krook
Postby Biggi_e » Mon Jun 11, 2007 7:43 pm
just buy an aftermarket alarm system
Postby DrLove » Mon Sep 24, 2007 8:26 pm
Hi guys, I'm a newbie here, from Canada (french).
I would like to know where it is easier to connect the 3 wires? I bought a white scanner from Ebay and I'm wondering where to connect it. From the radio? Under the driver steering?
Thanks for your help!
I bought my Solara 2 weeks ago, I love it. Fast, very agile, and great looking. Few modifications for now, but who knows the future.
Mazda 6 2010 6 speed black GS
DrLove
Postby woa_its_j3ff » Mon Sep 24, 2007 8:42 pm
welcome. read above man. just get an aftermarket alarm. I wanted to do the same thing, but then thought to myself, what's the point>? there is no real subsitute for security of a vehicle. Get an alarm system. If u had a light only in your car and it got broken into, how would you know. aftermarket alarms nowadays are pretty advanced and pricey as they go up. I recently just upgraded mine and I say it's well worth it. I have a little blue scanner on mine :). Imho opinion, get an alarm, no sense in having a light there with nothing to back it up..
Postby DrLove » Wed Oct 17, 2007 10:39 am
Hi guys,
I received my "streetglow LED Scanner" yesterday and installed it.
http://cgi.ebay.ca/Streetglow-White-LED ... otohosting
I don't have an alarm on the car. I wanted a "white" LED scanner, it's rare (everybody got the blue or red) and I don't like to be like everybody. I don't wanted the "batman" model, I prefer a "stick" model.
My scanner come with 3 wires, ( 12V, ground, alarm(-) ).
The alarm needs a "ground" when you want the LED to blink.
Some models blue and red that I saw (the ugly batman model) come with the "ignition" wire, it's smart and much easier than with the "alarm(-)" for the people who don't have a real alarm.
I used a relay and did a little shema to use the "ignition" wire to make the "alarm(-)". It was quite simple. I took a cable with 3 wires inside, plug it behind the factory radio and hide the cable to the LED scanner on the mirror.
Yellow-blue: 12V
Brown: Ground
Gray: Ignition
My radio wasn't working after my installation, I was a little bit anxious that I broke the radio cable, but luckly it was only a f****** fuse again ! lol I know It's better to unplug the battery but it was 5 PM and it was starting to be dark, so I needed to be fast.
If some people here wants the shema for the scanner witht he "alarm" wire, just PM me.
DrLove
Users browsing this forum: Google [Bot] and 33 guests
