SolaraGuy.com • View topic - cleaning the throttle body on a 00 V6?
Postby wekillyou » Fri Jun 08, 2007 3:26 pm
i saw the threads about cleaning them, but i only saw pictures of the 4 cylinder. is there a DIY with pictures of the V6... or am i missing something?
wekillyou
Postby Astro » Fri Jun 08, 2007 5:01 pm
Just buy some throttle body cleaner and spray and scrub (I use an old toothbrush) the inside and both sides of the butterfly. Make sure to wipe it clean before you start the car. That's all there is to it. :D
Postby anttarz » Fri Jun 08, 2007 5:25 pm
the best way to go is remove the entire throttle body and clean with carb cleaner
anttarz
Postby Astro » Fri Jun 08, 2007 5:51 pm
Why with carb cleaner? Any difference?
Postby boneezy » Sat Jun 09, 2007 5:09 am
dont use carb cleaner! its not the same... get the cleaner for fuel injected.. and read the DIY.. have fun, its a really awesome maintenance
1999 SE-V6 5spd
160,xxx miles
boneezy
Postby anttarz » Thu Jun 14, 2007 9:47 am
if you do not plan on dismantling the throttle body then do NOT use carb cleaner - it will damage fuel injectors. If you remove the throttle body then carb cleaner is fine.
by the way this is the a view of the rear on the throttle body (side that touches the manifold) which is not usually cleaned well if you do not remove it.
anttarz
Postby Akfahad » Thu Jun 14, 2007 9:42 pm
Astro wrote:Just buy some throttle body cleaner and spray and scrub (I use an old toothbrush) the inside and both sides of the butterfly. Make sure to wipe it clean before you start the car. That's all there is to it. :D
that's what I did...a total difference
Postby Paladin06Greg » Fri Jun 15, 2007 6:12 am
That's all you need to do anymore is really overkill.
Paladin06Greg
Torqued Solara
Torqued Solara
Postby agent007 » Fri Jun 15, 2007 10:29 am
will this help with CEL? still have mine saying im running lean...ill be be using injector cleaner to on my next refill
01 solara v6 se
trd kit, trd rims, trd suspension
greddy evo cat back
c/f hood
agent007
Postby wekillyou » Sun Jun 17, 2007 7:42 pm
sweet thanks guys, i'll do it tommorow on my day off.
wekillyou
Postby 99V6solaraSE » Sun Jun 17, 2007 8:19 pm
i just did cleaned the tb...
I didnt get smoke or anything.. It did start kinda funny though. Took a lil longer thang usual. I guess i can kinda notice it.. seems somewhats smoother. Maybe i expected a lot from what u guys were saying. I mean im at 96k miles on a 99 solara ... and i figured itd be super dirty. But it wasnt that bad. Maybe i didnt spray enough? I even used a toothbrush and a rag.
99V6solaraSE
Postby Astro » Mon Jun 18, 2007 6:52 am
99V6solaraSE wrote:i just did cleaned the tb...
The kinda rough start is normal, I believe that's just some left over cleaner being eaten up. Don't expect too much, it'll mainly smooth out your acceleration a bit. You don't need to spray that much, you should notice the difference when it's clean or not. Are you running a stock intake or a SRI? I think you'll notice more with a SRI, but I don't know since the intake was one of my first mods.
Postby 99V6solaraSE » Mon Jun 18, 2007 11:53 am
yea all i have is the CPe... but i guess it is kinda smoother...
but because i didnt notice any smoke or anything i was tempted to do it again just to make sure. But i guess ill leave it alone. I dont wanna do any unnecessary damage.
99V6solaraSE
Postby minchman » Mon Jun 25, 2007 12:19 am
Is it necessary to remove the front sway bar (the bar that goes from one strut to the other)? Just by looking under the hood, it seems to be in the way.
Did you disconnect any wires, or were you able to loosen and move the tube to the side?
minchman
Postby Midias » Mon Jun 25, 2007 4:59 am
I like to remove the back of the manifold and clean it form both ends on my V6
