SolaraGuy.com • View topic - Engine Light ....?
Engine Light ....?
Engine Light ....?
Postby TOYODRIVER01 » Tue Jun 12, 2007 9:17 pm
My check engiine light just came on !
took it to autozone read the ecu.
3 codes popped up
P0440
P0441
P0446
something to do with the evap?
any ideas how to fix???
TOYODRIVER01
Postby TOYODRIVER01 » Thu Jun 14, 2007 2:04 pm
i guess ill start with changing the GAS cap..
TOYODRIVER01
Postby unbalancedwood » Thu Jun 14, 2007 2:16 pm
P0440 – EVAP System Malfunction
· Vapor pressure sensor malfunction
· Fuel tank cap cracked, damaged or incorrectly installed
· Vacuum hose blocked, cracked, torn or disconnected
· Hose or tube blocked, cracked, torn or disconnected
· Fuel tank damaged
· Charcoal canister damaged
P0441 – EVAP Control System - incorrect purge flow
· Open or short in VSV circuit for EVAP
· VSV for EVAP
· Open or short in vapor pressure sensor circuit
· Open or short in VSV circuit for vapor pressure sensor
· Malfunction in VSV for vapor pressure circuit
· Vacuum hose blocked, damaged, or disconnected
· Charcoal canister malfunction
P0446 – EVAP System - vent control malfunction
· Same as P0441
unbalancedwood
Postby TOYODRIVER01 » Sun Jun 17, 2007 4:01 pm
well i reseted the ecu an tightend the gas cap
so far so good...
TOYODRIVER01
