SolaraGuy.com • View topic - Dead Driver Door Window 1999 Solara
Postby ZXLNT » Fri Jun 15, 2007 12:46 pm
So I go to "roll" down my window this afternoon on the way to work and its dead. It worked the last time I drove it. Today it was just dead. I can't find my manual since I moved a year ago or so. Anyone know if there is any kind of fuse for the motor? Haven't had a chance to do any testing yet to see if its the switch or the motor..
ZXLNT
Postby ZXLNT » Sun Jun 17, 2007 5:38 am
I took it apart today and it appears the motor is good. Bypassed the switch and it wouldn't roll down. Put it back together and it worked later on..
shrug...
ZXLNT
Postby NeFaRiOuS_SLE » Sun Jun 17, 2007 10:13 am
Not necessarily a fuse but probably a relay.
Postby ZXLNT » Thu Jun 21, 2007 3:19 am
Well it definately wasn't a fuse. Is there a relay in between the switch and the motor??
ZXLNT
Postby NeFaRiOuS_SLE » Fri Jun 22, 2007 2:53 pm
Usually under the hood there should be blocks larger than a fuse; try replacing the appropriate one as labeled on the lid... But then again it might also be the motor since most Gen1 cars have motor problems right about this time.
Postby ZXLNT » Tue Jun 26, 2007 1:35 am
Well seems to be working for now. Holding breath..
ZXLNT
