SolaraGuy.com • View topic - Romoved My sunroof Visor Grr..
Postby 2000BlackOnBlackSolara » Mon Apr 21, 2003 12:18 pm
Hi everyone I just removed my sunroof visor and there is like a permanent ring where the rubber sat on the car. Is there anyway I can get it off? I washed wax and tryed to scrub but it realy only faded it a little. Anyone else ever have this problem? Tks for any info on removing it ~Marshall
Postby SolaraLuva » Mon Apr 21, 2003 1:18 pm
i removed mine as well, at 1st but slowely it started fadiing away ...but i can still see tha "ring" so im hopeing for some tips on how to take this stuff off
hate me if u must...but ima keep on pimpin!
http://www.luxurymindz.com
SolaraLuva
Re: Romoved My sunroof Visor Grr..
Postby Flipside909 » Mon Apr 21, 2003 1:41 pm
2000BlackOnBlackSolara wrote:Hi everyone I just removed my sunroof visor and there is like a permanent ring where the rubber sat on the car. Is there anyway I can get it off? I washed wax and tryed to scrub but it realy only faded it a little. Anyone else ever have this problem? Tks for any info on removing it ~Marshall
The permanent ring is probably actual physical paint damage. The only way to get that off is to get it sanded down and refinished. That's the problem with adding accessories like that...it does more harm than good.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby Yanks0114 » Mon Apr 21, 2003 2:47 pm
I've had the same problem after I removed my mudgaurds. Left an outline of where they covered
Postby Mole » Mon Apr 21, 2003 3:25 pm
i dont understand. is the part removed on the exterior of the car? what is the reason removing it in the first place?
Postby Flipside909 » Mon Apr 21, 2003 6:01 pm
TRDMole177 wrote:i dont understand. is the part removed on the exterior of the car?
Yes. It's an exterior plastic accessory that expands/contracts/vibrates from resonance and wind drag. Of course it will do nothing but scrape up the paint.
www.clublexus.com
Flipside909
Postby BASolara99 » Mon Apr 21, 2003 7:59 pm
On the rings on the sunroof if you wet sand it with like 1500 grit wet or dry sand paper then you can buff it and wax it and it should come out
BASolara99
Postby sliver 2 » Thu Apr 24, 2003 6:28 pm
try Meguiar's X Scratch remover. Worked on mine .
sliver 2
Postby Flipside909 » Thu Apr 24, 2003 6:34 pm
If the paint damage is to the primer...you can't save it.
www.clublexus.com
Flipside909
Postby sliver 2 » Thu Apr 24, 2003 6:40 pm
if that's the case, then ur right.
Touch up comes in mind.
sliver 2
Postby 2000BlackOnBlackSolara » Thu Apr 24, 2003 7:04 pm
Ej I ended up just puttin the visor back on today, to save the hassle.
