SolaraGuy.com • View topic - Hazard/Turn Signals not working
Postby Omes01SLE » Tue Jul 03, 2007 12:57 pm
Don't know what happened, but all of a sudden the turn signals (both left and right) as well as the hazzards are not working. The lights are working, they are just not "blinking".
I've checked all the fuses and they are fine. I'm thinking it's a relay, but have checked the one in the engine comp. and it is also fine. HELP!
It's a 2001 btw.
thx
Omes01SLE
Postby Omes01SLE » Tue Jul 03, 2007 1:38 pm
Ok - I've narrowed the problem down to the Turn Signal/Hazard flasher. It's apparently behind the interior fuse panel - has anybody had to remove this before? do you know what it looks like (there are a lot of little black fuses back there)
thx
Omes01SLE
Postby bassthrive » Tue Jul 03, 2007 1:45 pm
If you cant find a blown fuse, have you done any work on the car where you had to remove the center dash trim? (i.e. radio installation, clock mod, wiring) I forgot to plug the hazard button back into its harness when I was finishing up my headunit install. This caused all my corner lights to malfunction.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Postby Mole » Tue Jul 03, 2007 3:21 pm
bassthrive wrote:If you cant find a blown fuse, have you done any work on the car where you had to remove the center dash trim? (i.e. radio installation, clock mod, wiring) I forgot to plug the hazard button back into its harness when I was finishing up my headunit install. This caused all my corner lights to malfunction.
+1
check the plug for emergency signal button behind the vent cover.
Postby s15lara » Thu Jul 05, 2007 2:57 pm
wow...im surprised no one said to check the blinker fluid :roll:
almost there...what do you think?
s15lara
Postby NeFaRiOuS_SLE » Mon Jul 09, 2007 10:52 am
^Well, in this case it doesn't lie with the fluid itself, but actually the fluid pump that's stuck and ineffective, kinda like how your car might react if the water pump failed.
Ask and ye shall receive :lol: .
Postby woa_its_j3ff » Mon Jul 09, 2007 10:55 am
s15lara wrote:wow...im surprised no one said to check the blinker fluid :roll:
lmao.
ok dude I had this problem a couple months back.
go to the dead pedal (next to the brake pedal on the left)
and stick your head under the dash and loook .. you'll see a small series of fuses. take out the one that says "flasher" not "relay" you'll be all set.
go to a store like advance auto parts. It costed me i think 7-11 dollars..
dont go to the dealership they will charge you for both the flasher and the relay, one being 40 bucks, other being 60. so you're looking at 100+ dollars for something you can easily fix for at the most 11 bucks.
good luck.
