SolaraGuy.com • View topic - Transmission Fluid Questions.
Postby Dawgz » Mon Jul 16, 2007 8:49 pm
So i have questions and concerns, please try to help me out.
ive got two possible problems:
1) We used this ATF fluid...Mobil 1 Synthetic ATF Multi Vehical Formula
http://www.mobiloil.com/USA-English/Mot ... c_ATF.aspx
Is that good?
2) i checked the dip stick for the tranny fluid and it was atleast an inch past the HOT indicator...meaning i have a bit too much in there...is that a cause for concern? or should i bleed it off the Tranny cooler we installed? (we added a bit more ATF fluid to compensate for the new Tranny cooler, but now i think we compensated way too much).
as always, any help is welcome and appreciated.
Postby Eye8Pussies » Mon Jul 16, 2007 11:01 pm
that's some good atf...
and too much usually won't make a difference, but it could cause shifting irregularities
as well, since you can just pull a line off the cooler and drain some atf that way, it's not a hassle to jack up the car and let it out underneath- you may as well do it.
Postby Dawgz » Tue Jul 17, 2007 12:22 am
Eye8Pussies wrote:that's some good atf...
alright, thanx for the input, but Fluid is good tho, like u said, so thats cool.
ill let some of the fluid out tomorrow and recheck.
Postby Mole » Tue Jul 17, 2007 12:29 am
did you flush or just do a service?
Postby Dawgz » Tue Jul 17, 2007 12:31 am
just service.
Postby TMMK Toy » Wed Jul 18, 2007 10:25 am
Did you get the fluid dropped? Too much can cause problems too so get that back to normal level asap
TMMK Toy
Postby bassthrive » Wed Jul 18, 2007 10:53 am
Thats the fluid I use. Good stuff. I was also confused at first since Mobil changed the label on the bottle to Mercon V.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
