SolaraGuy.com • View topic - door ,,,,
door ,,,,
door ,,,,
Postby sliver 2 » Thu Apr 24, 2003 6:26 pm
need help on disassembling the doors on my 99 sle. door panels to be exact.
Ur help is greatly appreciated. Thanx.
sliver 2
Re: door ,,,,
Postby Flipside909 » Thu Apr 24, 2003 6:36 pm
sliver 2 wrote:need help on disassembling the doors on my 99 sle. door panels to be exact.
Unscrew the screw located in the door grab pocket. Pry up the bottom part of the door with a flat tool. These pieces are held down by fasteners. There is also a fastener holding down the door on the part hidden behind the dash when the door is closed. I forgot what else...but basically everything lifts up and away after you have everything unbolted and unfastened. Make sure you unplug the wiring for the door locks and speakers when removing the whole panel.
www.clublexus.com
Solaraguy.com OG. ;)
Flipside909
Postby BASolara99 » Thu Apr 24, 2003 7:55 pm
Theres a screw behind the handle and one in the try where the windows and locks are theres two on the bottom of the door then one hid with a little cap on the place behind the dash then one under the try after you take it out think thats it see ya
BASolara99
Postby Flipside909 » Thu Apr 24, 2003 8:03 pm
Ummm can you stop posting like you ran out of breath? I will remove them if they don't make sense.
Thanks,
Moderator
www.clublexus.com
Flipside909
Postby FLASH » Thu Apr 24, 2003 8:39 pm
Yea thats hard to understand......are you doin Suicide/Lambo Doors? Or just new sound system?
==FLASH==
(Sister's) 2011 "Pink Prius"
FLASH
Postby Jaimster » Thu Apr 24, 2003 9:39 pm
BASolara99 wrote:Theres a screw behind the handle and one in the try where the windows and locks are theres two on the bottom of the door then one hid with a little cap on the place behind the dash then one under the try after you take it out think thats it see ya
WTF!
This is earth.....welcome! :wink:
Jaimster
Postby xyntax » Thu Apr 24, 2003 10:45 pm
I'm sorry, I'm not usually mean but I gotta say this guy is a RETARD. I can't stand reading that! Oh well, it's been a tough day for me I guess. :evil:
delete my post if you must.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby sliver 2 » Fri Apr 25, 2003 4:46 am
actually, am just sound proofing the front doors. Just did the back yesteday. Big difference. And no vibrations too. Thanx for the info guys.
sliver 2
Postby happy_aggies » Fri Apr 25, 2003 7:33 am
Hey... it's not that hard guys...
U just gotta pause every time you read 'and' & 'then'. :wink:
PS: If I can understand, y'all should be able to... my IQ is only 126 :P
happy_aggies
Postby krook » Fri Apr 25, 2003 4:27 pm
yah, i could understand it...sort of. let's just back up off BASolara for a little bit. one person's guidance is enough, and i'm sure with enough 'flipside encouragement' he'll get the hang of it.
as for the person removing the door. there should be 5 screws holding that door in. find it. after that. pry the door off with your fingers starting from the bottom; you're looking for 'door fasteners' that are plastic. these just pop in.
good luck
krook
Postby sliver 2 » Fri Apr 25, 2003 6:58 pm
did it this morning. The car is now sound and vibration proof. Thanx again ppl. BTW, anybody here done this b4? If so, what kind of insulator u used?
sliver 2
