SolaraGuy.com • View topic - Wobble
Wobble
Wobble
Postby twalhof » Thu Jul 26, 2007 1:37 pm
I have 02 Solara Convertible and have a wobble in the wheel.
I have put 3 sets of tires adn one new Axel and it is still there. any help
twalhof
Postby Traceur » Thu Jul 26, 2007 1:47 pm
You replaced the Tires,
and the axel,
and you havnt tried a new rim?
sounds to me like you have a bent rim dood..
or you need a front end alignment?
did you properly balance the tires?
Is it a wobble in the steering wheel? and if so what speed does it start at?
Traceur
Wobble
Postby twalhof » Thu Jul 26, 2007 2:22 pm
The Toyota Dealer and Good Year have balanced the and Aliegend it 2 time's
twalhof
Postby SolaraBlue » Thu Jul 26, 2007 3:30 pm
sounds like a bent rim to me... or your frame... hope not though.
good luck.
Postby Traceur » Thu Jul 26, 2007 4:24 pm
try some different rims..
in fact.. i have a set of stock 15inch alloys with near new michelin hydro edges on em, give ya a good deal if it ends up being the rims...
Traceur
Postby Solarafreek » Thu Jul 26, 2007 5:00 pm
If its front or back just use your spare and figure out "bum" wheel.
Solarafreek
Postby indiglosolara » Thu Jul 26, 2007 5:14 pm
Are you getting this consistantly?? Or only on certain roads???
I am asking this because on certain roads the rain grooves can give you a wobble effect due to the tires tread locking into it and following the lines.
This happens allot to me on one part of the i10 freeway here in so. cal.
If that is not the case I would check your wheels. If they did a high speed balance they will be able to tell you that the wheels are bent or not.
Do you have Aftermarket wheels or OEM???
If aftermarket also check if you have the hub centric rings on.
indiglosolara
Solara 2 xB
Solara 2 xB
