SolaraGuy.com • View topic - can you drive w/o the dogbone engine mount?
Postby SC V6 » Tue Jul 31, 2007 6:32 am
I was wondering if you can drive a solara without the dogbone mount.. the reason I ask is that I may swap my dogbone mount with superpoly pro bushings in it, to a member with the stock bushings..
thanks in advance
SC V6
Postby ClassySolaraGuy » Tue Jul 31, 2007 7:07 am
You could but wouldn't recommend it. I would think it would put a lot of stress on your other engine mounts.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby Paladin06Greg » Tue Jul 31, 2007 7:50 am
DON"T DO IT!!!!! :evil:
Paladin06Greg
Torqued Solara
Torqued Solara
Postby SC V6 » Tue Jul 31, 2007 7:52 am
do you have a reason for your post? or just an opinion? "Don't do it" is as good as a "do not feed the animals" sign
SC V6
Postby DatSRBoi » Tue Jul 31, 2007 8:58 am
You can do it as long your cars going to be driving on a flat road with no bumps, hills, nor you will not push the car not even off the light medium.
The engine will rock (you know like when it moves back in forth because of the torque). It will cause you to put stress on your drive axle to where it might jump the gears on them or break, other mounts might rip, and so forth. Is it still your daily car?
Postby SC V6 » Tue Jul 31, 2007 9:23 am
I'm asking for someone else... We are going to swap engine mounts because I have the superpoly pro bushings in mine, and don't need it since i'm stock again.
SC V6
Postby PhreakdOut » Tue Jul 31, 2007 10:10 am
Going without a dog bone mount will allow the engine to torque roll excessively. To give yourself an example, disconnect one end and have someone put the car in gear with the brakes on. Slowly increase the throttle and watch the engine roll. You will see how much the engine moves at take off.
Going without the mount gains you nothing. In fact, you lose some torque in engine roll because the torque is not transferred into the driveline. Drag racers of RWD cars would use solid engine mounts to eliminate torque loss in engine roll.
Some FWD racers use a solid mount (adjustable like a tie rod) or change to polyeurathane (sp) bushings which have less flex. The downside is that it is harder on the remaining engine / trans mounts and NVH is affected. (More engine vibrations transferred to the chassis.)
If you are doing an engine swap, I would look at the new engine's dog bone mount and have someone fabricate a mounting point on your chassis and an adjustable dogbone to match.
Just my 2 yen.
EDIT: My bad SC, I didn't see you were the author. You know all this basic stuff already. If you mean just a temporary thing driving w/o the bone, it's no problem. Just take it easy when pulling away from a stop. Most movement occurs at that moment.
Postby SC V6 » Tue Jul 31, 2007 10:15 am
I'm just lookin to sell mine... but I need a stock one back... I'm all stock now, so I don't need the superpoly pro bushings anymore... I figured it would move a bit, but as long as I was nice it should be alright.
SC V6
Postby DatSRBoi » Tue Jul 31, 2007 11:13 am
SC V6 wrote:I'm just lookin to sell mine... but I need a stock one back... I'm all stock now, so I don't need the superpoly pro bushings anymore... I figured it would move a bit, but as long as I was nice it should be alright.
I shall miss your car..
An another super solara down into the history book.
Postby SC V6 » Tue Jul 31, 2007 11:15 am
I know... sad day.. i was super upset when I pulled the charger... the car isn't want it was anymore.. its completly stock now (auto and everything) and its just not the same
SC V6
