SolaraGuy.com • View topic - Got my Optima Redtop installed (pics)
Postby Kenz » Wed Aug 01, 2007 6:37 pm
Installed my optima today. It looks allot nicer then the OEM battery. I had to redo all the wiring, but I took my time and did everything properly... Also added wire loom on all of the wires and got some terminal covers. I'm kind of a neat freak so everything had to be perfect.
I think it looks nice 8)
Yeah, I could have got the direct fit battery, but I had this one already from my old car. So it took about 20$ of parts, a spacer to raise the battery about an inch, and a few hours to make everything fit nicely.
In the last picture you can see the silverstar bulbs I put in the corner lights. I like they way they look over the amber color ones.
- Mack
Silver `03 i4 5 Speed
Dropped w/ Tein & KYB
OBX Cat Back
Kenz
Postby ClassySolaraGuy » Wed Aug 01, 2007 7:13 pm
Nice install. 8) Nice job on keeping that engine bay clean! I like! :D
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby NVDIS1 » Wed Aug 01, 2007 7:26 pm
:o looks really good! great job!
Postby SleeperSolara » Thu Aug 02, 2007 9:17 am
Looks nice man.
Postby woa_its_j3ff » Thu Aug 02, 2007 4:25 pm
I need a red top. did you buy yours online?
Postby Kenz » Thu Aug 02, 2007 6:33 pm
Thanks for the comments, I did a quick write up in case anyone else wants to put one of these in their Solara.
I got mine at autozone about a year ago. They go for a bit less on ebay , but shipping a battery has got to suck.
You can get an exact fit redtop battery and not have to change anything. But they aren't as common. I don't think the yellow tops (deep cycle) are even made in our OEM size.
If you do get the standard model like mine...
-You have to relocate one of the ground wires.
-Reroute the positive wires, they are bunched together in this big mess of plastic tubing and electric tape.
-Replace the OEM battery terminals with new ones of your choice.
-*Most Important* you need to make a spacer to get the battery about 1.4" taller, or it won't hold in place. The last thing you want to happen is your battery to move out of place, or worse fall out and take all the wires with it :o
- Don't forget to spray some anti corrosion on the terminals, then cover them with rubber or plastic protectors.
- Mack
OBX Cat Back
Kenz
Postby Sebas007 » Thu Aug 02, 2007 6:36 pm
Why do you have to do those step ??
Kenz wrote:...
Postby Kenz » Thu Aug 02, 2007 6:56 pm
Sebas007 wrote:Why do you have to do those step ??
Kenz wrote:...
One of the ground wires is to short unless you move it to a different threaded hole, or replace it with a longer one.
Same deal with the positive wires, they are bunched together in this tubing behind the battery tray, taking them out of it gives you extra wire.
The factory terminals are not deep enough/ the wrong ones to fit the redtop.
- Mack
OBX Cat Back
Kenz
Postby aleki2424 » Thu Aug 02, 2007 7:32 pm
i had to look twice to confirm u had a gen 1. great job on the clean bay man, . neat
aleki2424
