SolaraGuy.com • View topic - Sounds like air coming from brakes
Postby kaarona1 » Thu Aug 02, 2007 5:04 am
I recently changed my rotors and now when I press on the brakes it sounds like there is a constant air flow (hissing sound). Even when I am stopped, if I compress the brake pedal, it make the sound. Possible an air leak in the break line?
Any thoughts guys?
Thanks
kaarona1
Postby Meow » Thu Aug 02, 2007 5:27 am
Could be, or it could be your brake master leaking. Do your brakes suck?
Meow
Postby kaarona1 » Thu Aug 02, 2007 5:41 am
No, my breaks seem to work fine.
kaarona1
Postby SolaraBlue » Thu Aug 02, 2007 7:16 am
BUMB
WAHOOOO!!!!!!! im having the same problem!!!!!!!!
its been going on for months. my dealer and various other places cant figure out the problem.... ANYONE?!?!?!?!?!?!?!?!
Postby SC V6 » Thu Aug 02, 2007 7:20 am
when you push on the brakes it uses vacuum from the motor, so you could be hearing that... thats a normal thing... if your brakes are working fine, then its probably supposed to be happening.
If it was leaking air from the master cylinder, then it would be harder to press the brakes (like when your car is turned off)
SC V6
Re: Sounds like air coming from brakes
Postby ClassySolaraGuy » Thu Aug 02, 2007 7:27 am
kaarona1 wrote:I recently changed my rotors and now when I press on the brakes it sounds like there is a constant air flow (hissing sound). Even when I am stopped, if I compress the brake pedal, it make the sound. Possible an air leak in the break line?
Any thoughts guys?
Thanks
There shouldn't be any air leaks unless you undid the caliper. You should have it checked out by a brake shop unless you know how to bleed your brakes.
ClassySolaraGuy
1 Rockin' Solara
1 Rockin' Solara
Postby kaarona1 » Thu Aug 02, 2007 9:48 am
I did disconnect the calipers and C-Clamped them back to put new pads on, as I have done in the past, with no problems.
Would bleeding them solve this?
kaarona1
Postby Meow » Thu Aug 02, 2007 12:15 pm
Actually, if your BMC is leaking, your pedal will be much squishier, as it won't be able to exert the same amount of pressure on your rotors. I know, because that's exactly what mine is doing now =)
Meow
Postby NeFaRiOuS_SLE » Thu Aug 02, 2007 10:40 pm
Not to change the subject, but damn that's a tight sig, Meow.
Postby funboy102 » Thu Aug 02, 2007 11:36 pm
kaarona1 wrote:Possible an air leak in the break line?
Any thoughts guys?
Thanks
there shouldn't be air in the brake line... there should be brake fluid, just a FYI
funboy102
Postby Meow » Fri Aug 03, 2007 7:17 am
NeFaRiOuS_SLE wrote:Not to change the subject, but damn that's a tight sig, Meow.
Thank you good sir =) I have to spend my time at work somehow haha.
Meow
Postby nj99solara » Fri Aug 03, 2007 7:29 am
I had the same problem for a couple of months,but I finally figured it out about 3 months ago (with the help of a friend). It was air leaking out of the master cylinder, The small paper gasket right behind the fluid container had dried up and ripped. I was going to buy a new one from the dealer (less than $2.00) but we figured what the hell and we cut out a piece of head gasket material to fit and put that in it's place and the hissing stopped.
BTW,it did not affect my braking at all it was just annoying to hear everyday.
Good Luck with fixing yours,I'm glad I could help.
-4500k HID Bi-xenon kit
-4500k HID Fogs
-5% Tint in rear
-Tinted Stock Taillights
-Shaved Emblems
nj99solara
Postby kaarona1 » Tue Aug 21, 2007 12:40 pm
Sorry for the delay... Just got back from Scotland... When you say behind the fluid container, you are talking about under the hood, right? Dumb question, but just want to make sure.
Thanks
kaarona1
Postby Sebas007 » Tue Aug 21, 2007 12:56 pm
did you replace your rotors with stock ones or slotted-drilled one ?? If so it is the drilled-slotted that makes the sound.
Postby NeFaRiOuS_SLE » Tue Aug 21, 2007 2:11 pm
kaarona1 wrote:Sorry for the delay... Just got back from Scotland... When you say behind the fluid container, you are talking about under the hood, right? Dumb question, but just want to make sure.
Thanks
Yeah, it's under the hood and in the upper left corner... It's a clear container with fluid ranging from yellow (good) to black (bad, replace ASAP) with a black rubber top.
