SolaraGuy.com • View topic - Torque rod installation instructions
Postby nammby77 » Fri Aug 03, 2007 7:45 am
I've been browsing the forums trying to find clear instructions(installation,pics with complete job and the like).All i can say is i'm still looking.I don't have the same knowledge about cars like most users here but i'm more than willing to do it on my own.
nammby77
Postby Astro » Fri Aug 03, 2007 8:47 am
Is this what you're looking for? I just did a search for Jim's torque rod. The pics aren't showing up anymore, but there's 1 pic of it instaled that I posted further down on page 1. Also, you don't need to worry about supporting anything, just remove and install. I found it much easier to remove the fans, then it went very quick.
http://www.solaraguy.org/viewtopic.php?t=16123&postdays=0&postorder=asc&highlight=jims+torque+rod&start=0
Postby nammby77 » Fri Aug 03, 2007 8:50 am
Yeah,that's a big help.Does it need any support or do you just install and forget?
nammby77
Postby Astro » Fri Aug 03, 2007 9:04 am
No support, just install it :D
Postby Chinky420 » Fri Aug 03, 2007 10:39 am
TIPS:
1) DO remove the fan, it makes the process about 10x easier
2) DO in the morning, before driving. once the headers heat up, it'll be rough, since you're going to be working so closely to them
3) read the thread on howto do it. i was waiting for pictures too, but really didn't need them once i got into it. it's just a simple remove and replace, where you have to unscrew maybe three bolts to remove.
4) when removing the bottom bolt (the one that will go through the eyehole on the new rod), be sure to attack the driver side of the bolt/nut combo. the nut is welded on, and that was one thing i had to read carefully in the instructions (since there were no pics). i eventually broke an openended wrench by trying to remove the bolt that was welded on (stupid).
5) Astro's pic of the rod installed is helpful, if for no other reason, than the facts it shows the proper location of the part, and also that the only part that goes above the transmission mount is the two nuts that secure the torque rod to the topside of the mount.
most of the bolts removed will be metric 14mm, and 17mm. it's handy to have two of each wrench (openended, not socket) for the lock-nuts (the two bolts that tighten together). once the bottom bolt is broken/loose, it's easy to remove by hand.
once i had it off, i just threaded down the red bushings on the new torque rod, then hand threaded them upward, until desired tightness was achieved.
also, read the old install thread, because some people had various opinions on howto keep the bottom of the torque rod from moving around (there's much more space left around the heim joint/ball joint on jim's torque rod than on the stock one). personally, i used parts from the OEM shock; one rubber bushing, and one curved washer; to space it evenly, and to keep the heim joint from moving around.
hope that helps (if you havent already installed it)
Chinky420
Postby nammby77 » Fri Aug 03, 2007 10:47 am
Yes that helps a lot,thanks for the details.I'll get it done on sunday,a lot of driving until then.
nammby77
Postby Dawgz » Fri Aug 03, 2007 10:48 am
u dont have to remove the damn fan....
Postby Paladin06Greg » Fri Aug 03, 2007 12:17 pm
AMEN!!!!
Dawgz wrote:u dont have to remove the damn fan....
Paladin06Greg
Torqued Solara
Torqued Solara
Postby TMMK Toy » Fri Aug 03, 2007 9:27 pm
It helps to remove the fan if you dont have midget arms
TMMK Toy
Postby gnegroni » Fri Aug 03, 2007 9:33 pm
Uh, uuhhhhuuu, he said mmiddget arms! Uh, uuhhhhuuu!
gnegroni
Postby 99V6solaraSE » Sun Aug 12, 2007 10:00 pm
ok so i tried to figure it out through the tutorial without the pics...
i took a picture of mine installed from how i figured it out to be..
Does it look about right?
99V6solaraSE
Postby Dawgz » Sun Aug 12, 2007 10:21 pm
TMMK Toy wrote:It helps to remove the fan if you dont have midget arms
im 6'1, i highly doubt my arms can be considered anywhere near "midget arms", im also @ 210lbs, so im not a light weight lol.
Postby TMMK Toy » Tue Aug 14, 2007 4:27 pm
True. 5'8 160ish here. Guess I aint limber enough
TMMK Toy
Postby Astro » Tue Aug 14, 2007 5:14 pm
99V6solaraSE wrote:ok so i tried to figure it out through the tutorial without the pics...
Looks good!
