SolaraGuy.com • View topic - Mileage changes
Mileage changes
Mileage changes
Postby Jeffrey Olson » Sun Aug 05, 2007 6:01 pm
I got my 99 6 cylinder SE last July. It got between 30 and 32 mpg until it started getting cold in later October. All winter and spring it got 25 to 26 mpg. When the temperature got back into the 90s, I'm getting 30 mpg again.
Is this a simple aberration - my car, or is this something others experience?
By the way, I have done nothing to the car over the 25,000 miles I put on it during the last year except change oil every 3k to 5k, and suspension parts.
Jeff...
Jeffrey Olson
Postby Mole » Sun Aug 05, 2007 6:10 pm
different gas additives from the gas stations.
Postby Midias » Sun Aug 05, 2007 6:41 pm
Could it be possiable that with the colder more dense air of the winter more fuel is being added to keep the proper mixture.
Postby kwyse » Sun Aug 05, 2007 9:31 pm
It takes way longer for your engine to warm up in the cold weather, thus your gas mileage is awful because you are not at the optimum driving conditions. In summer you engine warms up in under a minute instead of say the five minutes it might take in winter. I usually averaged around 250 miles per tank this winter and am now pushing 400 for summer.
kwyse
Postby Jai_Jai_Binks » Mon Aug 06, 2007 4:27 pm
kwyse wrote:It takes way longer for your engine to warm up in the cold weather, thus your gas mileage is awful because you are not at the optimum driving conditions. In summer you engine warms up in under a minute instead of say the five minutes it might take in winter. I usually averaged around 250 miles per tank this winter and am now pushing 400 for summer.
^^^ DING DING DING, we have a winner. As indicated, in the winter months, the cold start will bring up your rpms to reduce the time it takes to warm up the car. The engine revving decreses MPG's. Also the gas blend in the winters is not the best for mpgs, summer has the best blend for gas.
Postby philosophicaljt » Mon Aug 06, 2007 5:07 pm
Jai_Jai_Binks wrote: Also the gas blend in the winters is not the best for mpgs, summer has the best blend for gas.
it has more to due with this than anything.
2004 Solara SLE V6
Search
philosophicaljt
Postby 99V6solaraSE » Mon Aug 06, 2007 10:38 pm
i almost thought he had the 4cyl.. cuz thats some damn good gas mileage
99V6solaraSE
Postby Snake2715 » Tue Aug 07, 2007 9:16 am
Wow so should I be pulling above 30 mpg? I assume it has something to do with sea level as well correct?
-Josh
Snake2715
Postby wekillyou » Tue Aug 07, 2007 7:40 pm
i managed 450+ on a tank last week. i try to not drive like a dickhead.
wekillyou
Postby 99V6solaraSE » Tue Aug 07, 2007 9:50 pm
ok i can see 450 being possible with a lotta highway miles in that...
but getting 30 - 32 mpg is getting 540 -576 miles on one tank.. thats pretty insane imo
99V6solaraSE
Mileage changes
Postby Jeffrey Olson » Tue Aug 07, 2007 10:45 pm
In the summer I regularly go 500 miles between fillups. I drive 60 - 65 mph on rough country roads using the cruise control. I know all gas gauges read differently, but when I hit the 1/4 mark, I am at 150 miles, the 1/2 mark, 300 miles, and the 3/4 mark, about 400. Tailwinds raise the mileage 3 to 4 mpg. Headwinds cut it 2 to 3 mpg...
I think I spend too much time in the car... javascript:emoticon(':D')
Jeff...
Jeffrey Olson
Postby wekillyou » Thu Aug 30, 2007 6:37 pm
i do about 85% highway miles. and i go between 80-100mph. :evilbat:
wekillyou
