SolaraGuy.com • View topic - O2 Sensor
O2 Sensor
O2 Sensor
Postby Chinky420 » Wed Aug 15, 2007 12:45 pm
this is for anyone who has thrown a P0135 (bank 1 sensor 1) oxygen sensor malfunction code.
i tried to find where this was myself, but could not find where the sensor plugs into the exhaust.
so far, what i know is that the bank 1 sensor 1 is located on the rear bank (near the firewall), and that it screws out.
i also know that there are three sensors, one for the front bank (bank2), one for the rear bank (bank1), and one downstream of the catlytic converter.
I STILL HAVE NO IDEA WHERE THE B1S1 SENSOR IS though!
i jacked up my front end and slid under the engine bay, but i couldnt find it. i checked from above the engine, cut still could not find it. i checked the haynes manual and couldn't find it there either (maybe i'm looking in the wrong sections). and i did a search here, and scrolled through the tutorial section, and couldn't find anything that would help me.
please, any help locating this sensor so that i can replace it would be appreciated.
Chinky420
Postby Dawgz » Wed Aug 15, 2007 1:05 pm
The rear header, ontop the EGR fitting.
Postby Chinky420 » Wed Aug 15, 2007 1:29 pm
what does the EGR fitting look like?
and would i be better off getting at the sensor from above or below?
Chinky420
Postby Dawgz » Wed Aug 15, 2007 1:35 pm
Chinky420 wrote:what does the EGR fitting look like?
from below is ur best bet i think.
Here's a pic of the header im going to be using in a few days.
Its the rear header, the o2 sensor is ontop, the EGR is the fitting u see on the bottom.
Postby Chinky420 » Wed Aug 15, 2007 3:01 pm
thanks dawgz, the pic is helpful.....
now hopefully i can manage to buy the correct O2 sensor, since there are like, 6 different types.
Chinky420
