SolaraGuy.com • View topic - my 2000 solara got some problems....
Postby SoCalSolara » Fri Aug 17, 2007 11:42 am
just bought this 2000 I-4 Solara last month.
1. engine light went off ( P0240) the shop said its cat covertor is bad. Could it be something else besides the cat convertor? like O2 Sensor or Air-fuel sensor? any suggestion ?
2. driver side window motor is dead and i can't close the window now! :x
SoCalSolara
Postby Dawgz » Fri Aug 17, 2007 11:46 am
im sc'd and the cat is basically what the dyno shop is telling me is the reason for my poor whp, i have a 2000 model too. So im having a member on here (midas) make me a bolt up High flow magna flow Cat.
and for ur #2 question, go to Toyota and have them order a window Regulator for ur driver window.
Postby Americanctm10 » Fri Aug 17, 2007 11:51 am
ouch. new window motor is over $200 bucks, check ebay if you dont wanna go to the dealer
Americanctm10
Postby SoCalSolara » Fri Aug 17, 2007 12:19 pm
[quote="Dawgz"]im sc'd and the cat is basically what the dyno shop is telling me is the reason for my poor whp, i have a 2000 model too. So im having a member on here (midas) make me a bolt up High flow magna flow Cat.
will that High flow Magnaflow cat pass the smog? is it legal? i'm in California
thanks
SoCalSolara
motor
Postby NRDriver » Fri Aug 17, 2007 12:25 pm
did you test the motor. it may be a bad switch.
NRDriver
Postby Ruski » Fri Aug 17, 2007 1:46 pm
Americanctm10 wrote:ouch. new window motor is over $200 bucks, check ebay if you dont wanna go to the dealer
a new window motor doesn't cost 200$ go to your local car part store like auto zone and buy one there under 100$
Postby Americanctm10 » Fri Aug 17, 2007 2:25 pm
^^ i didn't know they sold them, huh.
Americanctm10
Postby SoCalSolara » Fri Aug 17, 2007 2:33 pm
ok, thanks all.
window motor is easy to replace.
but my 1st problem, CEL P0240 is a headache. Could be the cat convertor or O2 sensor that I need to spend some time to solve it. Hope it won't end up wasting money buy the wrong parts.
SoCalSolara
Postby Ruski » Fri Aug 17, 2007 6:18 pm
i cant seem to find that code in the tutorial with all the cel codes ..weird
http://www.solaraguy.org/viewtopic.php?t=16121
Why don't you go to the same store you might by your motor from and use there obd2 reader to read your codes
Postby SoCalSolara » Mon Aug 20, 2007 4:09 pm
oppooos......
the my CEL code should be P0420.....
SoCalSolara
Postby mazen222 » Mon Aug 20, 2007 5:14 pm
i had that same window problem 3 weeks ago...
for solara v6 99, there was no where to find it online, so i had to go to Toyota dealer and order it from ontario (150$)
just make sure that you can hear the motor running when you press the window button, if you can hear it, stop playing with it and order a window regulator without the motor. If you cant hear the motor then the bill will go up
mazen222
Postby SoCalSolara » Mon Aug 20, 2007 10:57 pm
mazen222 wrote:i had that same window problem 3 weeks ago...
got it, thanks
SoCalSolara
Window Problem
Postby dc3886 » Fri Aug 31, 2007 10:06 am
I had the same window problem on my driver side window, it was a bad switch. It was a pretty easy fix.
dc3886
