SolaraGuy.com • View topic - clean(dum)
clean(dum)
clean(dum)
Postby ron33030 » Mon Aug 27, 2007 8:18 pm
i want to know if u can clean a cat-back if yes how
ron33030
Postby MCOjerry » Mon Aug 27, 2007 8:20 pm
Well, you could use toilet paper, perhaps a baby wipe... but I don't think your cat is gonna like it very much.
:rofl:
Postby SleeperSolara » Mon Aug 27, 2007 8:22 pm
What do you mean clean the cat-back?? :lol:
Like the internal of the pipin'??
Postby ron33030 » Mon Aug 27, 2007 8:26 pm
cat converter were the honey com is at......my cat converter is stuff
ron33030
Postby Dawgz » Mon Aug 27, 2007 8:36 pm
its clogged? how do u know?
Postby ron33030 » Mon Aug 27, 2007 8:43 pm
because lately my car has been lacking in power it is slower on take off n when iam on the highway it wont pass 80mph and rpm 4000 and my check light is on..i scaned my car and it show P0401 EGR but i dont think is that
ron33030
Postby philosophicaljt » Mon Aug 27, 2007 8:50 pm
either hollow it out (I do not reccomend) or replace it.
2004 Solara SLE V6
Search
philosophicaljt
Postby ron33030 » Mon Aug 27, 2007 8:53 pm
quick ??????? were is the EGR located so i can fix that check light
ron33030
Postby NeFaRiOuS_SLE » Mon Aug 27, 2007 9:03 pm
That could be other things... Unless you've been buying mom-and-pop gas and the car burnt oil or ran ridiculously rich, a catalytic converter is designed to friggin' last (especially on Toyotas where they're more generously spread in the manifold)... Rightly so when it's usually platinum-coated inside! Also, when was your last smog check? If it failed, then there's SOME merit, but it's usually regarded as a worst-case scenario.
You have a legitimate EGR problem
Postby SirTrixMagoo » Sun Sep 02, 2007 7:55 pm
the power issues you mentioned are textbook symptoms of an EGR fault. get that fixed and everything will go back to normal. you can try replacing the egr valve yourself, and that will most likely take care of the cel, but if you've been having an issue, most likely the passageways are clogged with carbon buildup and will need to be cleaned out. cleaning the EGR passageways is a bit more complicated than a simple valve r&r. I would recommend a dealer repair or equivalent (someone who knows where to look for excessive deposit buildup.)
SirTrixMagoo
Postby PXLpainter » Sun Sep 02, 2007 7:58 pm
Chew some of this - should work! :lol:
