SolaraGuy.com • View topic - removing battery
removing battery
removing battery
Postby pbartosz » Tue Aug 28, 2007 5:51 pm
hey guys
So I want to remove my battery and can't remove the negative terminal nut with a ratchet, pliers won't fit and my wrenches are too big.
what tool should I use?
thanks
pbartosz
Postby Solarafreek » Tue Aug 28, 2007 5:58 pm
HACKSAW FTW!!!
Solarafreek
Postby Americanctm10 » Tue Aug 28, 2007 6:01 pm
how can you not remove it with a ratchet? all you need is a 10mm socket
Americanctm10
Postby NeFaRiOuS_SLE » Tue Aug 28, 2007 6:08 pm
CAREFULLY spray some penetrating lube in it too (no not Astroglide :lol: ).
Postby aleki2424 » Tue Aug 28, 2007 6:27 pm
NeFaRiOuS_SLE wrote:CAREFULLY spray some penetrating lube in it too (no not Astroglide :lol: ).
lol... :drinking: user discretion advised
aleki2424
Postby tito53 » Tue Aug 28, 2007 11:18 pm
haha just needs elbow grease. i had the same problem when installing the HID's
tito53
Postby pbartosz » Wed Aug 29, 2007 2:07 pm
Americanctm10 wrote:how can you not remove it with a ratchet? all you need is a 10mm socket
did you use a deep socket? thats what I am assuming I guess I need to buy some.
and why is user discretion advised for lubing the area??
thanks for the input
pbartosz
Postby SleeperSolara » Wed Aug 29, 2007 8:11 pm
You can use a 10mm open wrench to loosen the battery terminal bolts.
Shouldn't be hard to take them off.
