SolaraGuy.com • View topic - clutch replacement
What upgraded clutch are you running?
Clutchmasters
2
25%
ACT
1
13%
SPEC
5
63%
Total votes : 8
clutch replacement
clutch replacement
Postby Akfahad » Fri Aug 31, 2007 11:34 am
I think I got all the manufacturers, but I can't remember sure. If you guys select other, could you please specify what you got. Also looking for feedback on personal experiences and what type of Stage your running? Read some old posts, wanna see if some of those responses hold true.
I'm also looking for the stereotypical signs of the clutch going bad, besides it slipping or out completely (the obvious one's).
Postby Eye8Pussies » Fri Aug 31, 2007 3:34 pm
spec stageIII and fidanza/spec lightened flywheel
it grabs like nobody's business....very small bit of room to play with = very easy to stall
great for occasional bumper to bumper traffic...but if you're in it several times a day.....don't do it...
Suggestion
Postby JMSinMaryland » Fri Aug 31, 2007 4:13 pm
TRD used to make one, don't know if there are any still available. When I replaced mine I went with OEM, it lasted me 95k with the S/C, I figure this one should last me just as long.
JMSinMaryland
Postby facevedo17 » Fri Aug 31, 2007 5:43 pm
Spec stage 2 / Fidanza flywheel like eye8pussies stage 3 " said if your in traffic a lot don't do it ......its a pain
let me add aswell stalls pretty easily till you get the hang of it
overall approvAL i LUV IT !!!!!! It stage 2 feels like stock but better ......
facevedo17
Postby Kenz » Sat Sep 01, 2007 7:20 pm
About how much does it cost to get the clutch replaced? Is it something that you can do yourself or is it a huge job?
- Mack
Silver `03 i4 5 Speed
Dropped w/ Tein & KYB
OBX Cat Back
Kenz
Postby facevedo17 » Sat Sep 01, 2007 7:51 pm
Price varies depending on mechanic off course for example my guy charge me like 350 and I provided the clutch and flywheel ..I got a qoute from another dude he was charging me like 600 and i had the parts already to give you an idea
facevedo17
Postby Eye8Pussies » Sat Sep 01, 2007 9:02 pm
350 for labor a clutch/flywheel job is dirt cheap...600 is more in the usual range.
you've got a cheap mechanic, man....lucky you.
And to answer Kenz's question....it's a big job. Unless you either have an engine hoist or a lift, you're best leaving the job for a professional. There's a reason why it costs a lot to do the job.
Postby Akfahad » Sun Sep 02, 2007 7:01 am
in terms of wear and tear, can you tell that your coming close to replacing the clutch based on how far you have bring out the peddle until it catches or is that just a theory people like to say?
Postby facevedo17 » Sun Sep 02, 2007 8:13 am
too soon for me to tell I had my install around like 3 months ago and so far no problems ..funny after it was put on and I was driving away it shut off on me you gotta feather that clutch now just luving it never going stock again as for the other brands I was debating between them but Dats was selling his spec for a good price brand new so I had to jump on it ....
As for the tear and wear thats a good question this is my first performance clutch so how can you tell ? anyone ?
facevedo17
Postby netherland24 » Sun Sep 02, 2007 8:31 am
i hear the same thing...
spec stage 3
and flywheel
i ordered them last night :) and hoping to get a koyo radiator...
00 SS Lara 277hp
05 DODGE RAM 1500 n/a
netherland24
Postby Kenz » Sun Sep 02, 2007 6:13 pm
Eye8Pussies wrote:And to answer Kenz's question....it's a big job.
Thanks for the info.... I figured that much, being a front wheel drive. I was just thinking maybe it was easier in a Toyota over a domestic or something.
- Mack
OBX Cat Back
Kenz
