SolaraGuy.com • View topic - installing new spark plugs
Postby Grnarowana » Tue Sep 11, 2007 8:11 pm
I was told that the spark plugs are in front and in the back of the engine bay. Do i need to remove the engine or a speical tool to change the back 3 spark plugs? I heard its really hard. Is it better if i just go to the automaechanic shop and let them do it?
What do you think the estimate is for a v6 1999 solara?
Grnarowana
Postby Dawgz » Tue Sep 11, 2007 8:33 pm
u gotta take the intake manifold off to get to the rear 3 spark plugs.
Postby JavaJoe_2 » Tue Sep 11, 2007 8:42 pm
Dawgz wrote:u gotta take the intake manifold off to get to the rear 3 spark plugs.
I don't think so.
A ratchet, extension and sparkplug socket can do the trick.
If you are a novice...take it in.
If you feel you can do it, go for it! I'm sure you can.
Go buy yourself a Haynes manual on your car and read all about it.
Don't be intimidated by it.
Got Boost?? :sweet:
JavaJoe_2
Postby bassthrive » Tue Sep 11, 2007 10:03 pm
DIY!
I have done it twice. All it takes is the right tools, patience and figuring out the best angle to come at it.
May I also suggest you use a spark plug socket with the little rubber ring inside it. Makes extracting the old plug out of the deep holes a lot easier. I also used two small socket wrench extensions instead of one big one. Stick the new plug in the socket with the extension, lower that into the hole, finger tighten, THEN attach the ratchet and snug it down (not too much). Don't forget to anti-sieze the threads and put dielectric grease on the plug contacts.
- Paul
y2k(1MZ)dWp
bassthrive
SolaraGuy Marklar
SolaraGuy Marklar
Lol
Postby JMSinMaryland » Wed Sep 12, 2007 7:08 pm
Anyone with a Supercharger do it yet? I plan to wait until 120k and do plugs/wires/timingbelt/waterpump/thermostat/cam/crank seals/etc/etc/supercharger oil
JMSinMaryland
Re: Lol
Postby JavaJoe_2 » Wed Sep 12, 2007 7:17 pm
JMSinMaryland wrote:Anyone with a Supercharger do it yet? I plan to wait until 120k and do plugs/wires/timingbelt/waterpump/thermostat/cam/crank seals/etc/etc/supercharger oil
Now that I am going to remove. I want to dress it up a bit. If you do all that why not and then clean everything
Got Boost?? :sweet:
JavaJoe_2
Re: Lol
Postby Dawgz » Wed Sep 12, 2007 7:59 pm
im pretty sure to get to the rear spark plugs u gotta remove the s\c...ITS REALLY tight back there...
when was the last time u did a timing belt change?
Postby Ruski » Wed Sep 12, 2007 8:03 pm
dawgs timing belts arnt replaced often.. 90to100k is recommended time.. and the S/c would have to be removed it will make the job so much easier.
Postby Eye8Pussies » Thu Sep 13, 2007 9:45 am
I think that it'd still be possible to do it with the blower on...presuming that you were one of the people who had done it without the blower before and with the stock intake plenum on before.
in the case of the gen3, replacing the stock intake plenum with the blower actually leaves MORE room between the firewall and the engine....I'm guessing that the stock intake on the gen3 1mzfe is longer than the gen4 ones
