SolaraGuy.com • View topic - Skweaking when pressing the clutch
Postby mazen222 » Sat Sep 15, 2007 2:26 pm
When i park next to a wall with my window open and press the cluch pedal, i hear a sweaking sound, like an old swinging wooden chair. The noise is comming from outside of the car, not the inside.
I think something related to clutch needs to be greased... what could it be?
Thanks!
mazen222
Postby Eye8Pussies » Sat Sep 15, 2007 3:15 pm
hmmm....there isn't much that can squeek....maybe the slave cylinder....the master shouldn't be able to squeek considering it's design....
have someone take a listen under your hood when you're pressing the clutch
Postby Akfahad » Sat Sep 15, 2007 4:53 pm
I have that noise too, only when I press and release the clutch pedal.
Postby Kenz » Sat Sep 15, 2007 5:09 pm
Same here, infact my other two cars that were manuals had the same noise too.
- Mack
Silver `03 i4 5 Speed
Dropped w/ Tein & KYB
OBX Cat Back
Kenz
Re: Skweaking when pressing the clutch
Postby Gregtrd » Sat Sep 15, 2007 7:55 pm
mazen222 wrote:When i park next to a wall with my window open and press the cluch pedal, i hear a sweaking sound, like an old swinging wooden chair. The noise is comming from outside of the car, not the inside.
Thanks!
its the clutch release bearing that goes on the clutch fork, trust.
Gregtrd
Postby 808Solara » Mon Sep 17, 2007 4:02 pm
ahhh me2...clutch release bearing needs lube..
808Solara
Postby Toy1mzfe » Mon Sep 17, 2007 7:30 pm
i have that too. hmm where is that?
