SolaraGuy.com • View topic - Brake Check
Brake Check
Brake Check
Postby Ransom8707 » Sat Sep 15, 2007 8:03 pm
Well would anybody know what parts of my brake system I would have to change. Heres the deal everytime I press on the brake and is bout to stop I get a loud whistling noise would anybody whats wrong with it? or what part I would have to replace. :-?
I tought I seen forum for this problem but I wasnt able to find after searching for awhile :evil:
Ransom8707
Postby Chinky420 » Sat Sep 15, 2007 8:06 pm
whistling noise?! beats me....if it's a hardcore squeak/squeal, then it's your pads about to go (or already gone)....if you get to the point where you hear a metal grinding sound, then your pads are gone, and your rotors are gone too.
why not take off your wheel and inspect the amount of brake pad left (there's a little looking 'window' on the caliper to see how much pad is left).
if it's not the pads or rotors, then you best keep asking and looking, cuz that's all i would say to check out
Chinky420
Postby SleeperSolara » Sun Sep 16, 2007 7:20 am
A whistlin' noise??
Or do you mean a squeakin' noise, that means the piece metal on the brake pad on the back is just movin' around everytime you brake, that's what makin' that squeakin' noise, that's if you have anymore brake pads left.
Postby Squid » Sun Sep 16, 2007 7:37 am
its the squirl that makes your car go, he is tired and happy he gets a "brake" when you slow down :drinking:
sorry had to do it.
take the wheels off and inspect!
Today is the Tomorrow you dreamed about Yesterday, So get off you ASS and do somthing!
04 lara se, all the extras from yota, RAZO shift knob (grey ipod sock when it gets hot :P)
Squid
Re: Brake Check
Postby Gadgetjq » Sun Sep 16, 2007 8:00 am
Ransom Wrote: "everytime I press on the brake and is bout to stop I get a loud whistling noise would anybody whats wrong with it? or what part I would have to replace?"
Ransom,
One guys 'whistle' is another guys 'squeel'. You don't say but I'll assume this just suddenly started and hasn't been happening since brake pads were replaced.
Your front brake pads (front & rear on the gen2) have a flat piece of metal on them designed to come in contact with the edge of your brake rotor when your pads are worn out.
If you ignore the noise that vibrating piece of metal makes (squeel or whistle) you'll soon have the bare metal backing plate in contact with your rotors. If that happens the backing plate usually gouges the rotors and they'll have to be turned or replaced.
Bottom line, pull your front wheels today and check the brake pads.
If this is just standard disk brake squeal you're describing it's caused by the pads vibrating. The fix is easy. Remove the pads and put some of the blue 'goop' made for the purpose (any auto supply store) on the backing plate. Let the goop set up then replace your pads. If the vibration continues, grind the front edge off the pad at a 45 degree angle so the part of the pad that touches the rotor first isn't right on the leading edge.
Cheers
Gadgetjq
Postby campfire9 » Tue Sep 18, 2007 6:45 pm
Here is a site that talks about Brake Squeal. Only 3 pages to print.
http://pages.sbcglobal.net/gorf/bmwtips ... queal.html
Here is a technical paper on the same subject and is in fact technical but VERY good. http://delphi.com/news/techpapers/1999/. Scroll down to paper 1999-01-0142 and click on it and you are ready to print. This one is only 8 pages. I printed both paper to keep.
Both of these are very enlightening and well worth the trouble to look them up.
campfire9
