SolaraGuy.com • View topic - Gauge lights are off. Suggestions?
Postby xfhu » Thu Sep 20, 2007 8:14 am
I have a 2001 Solara, and I accidentally connected the dimmer wire to the dimmer ground when I was installing a Pioneer stereo head unit.
Now the lights for some gauges (i.e., speedometer) don't light up. Basically,
these lights are controlled by the dimmer.
Could you provide some suggestions please? i.e., what are the things
to look into? Thank you.
I'm very good at going through electric diagrams and nailing down the
problem. In fact, I have the diagrams from 2001 Solara. If some clues
can be offered, I greatly appreciate.
xfhu
Postby woa_its_j3ff » Thu Sep 20, 2007 1:03 pm
fuse? recheck connections, wiring etc.
Postby Eye8Pussies » Thu Sep 20, 2007 1:17 pm
or it's possible that you may have burned out the dimmer as well
without the dimmer attached, your gauge cluster won't work (if it's the same as in the camry)
