SolaraGuy.com • View topic - Auto dimming mirror on 99 SE
Postby blue_hauder » Sat Oct 06, 2007 3:00 pm
I've got a 99 SE V6 5 speed. I went to the junk yard and found an auto dimming mirror off a 97 or 98 camry for a pretty good price while I was looking for some interior parts for my car. My question is what do I need to do to put it in? The camry had two wire going into the mirror but I am not sure where they went to. If I had to guess, I would say that one is power and the other is ground. Can any one help me on this one?
blue_hauder
Postby JavaJoe_2 » Sat Oct 06, 2007 3:52 pm
Let me know if this helps. One goes to the connector D1 block under the drivers dash and the other goes to the ground on the floor to the left of the pedals.
Got Boost?? :sweet:
JavaJoe_2
Postby Ruski » Sat Oct 06, 2007 4:35 pm
All you need is a power and a ground. my mirror that i had on my solara was wired to the cig lighter
Postby JavaJoe_2 » Sat Oct 06, 2007 4:43 pm
You still have to route the wire across the top of the windshield and down the pillar.
Got Boost?? :sweet:
JavaJoe_2
Postby Ruski » Sat Oct 06, 2007 4:46 pm
yea thats exactly how i routed mine.. use thin wire.. and it easily slips behind the windshield and head liner.. and then pull he pillar of and route through there .. Pretty simple
Postby bronzemaxell » Sun Oct 07, 2007 2:13 pm
Ruskimafia wrote:yea thats exactly how i routed mine.. use thin wire.. and it easily slips behind the windshield and head liner.. and then pull he pillar of and route through there .. Pretty simple
i just installed auto dimming mirror on my 97 camry, i bought the GM grand prix 2002 auto dimming mirror with compas and temp on ebay for $45 shipped, the one that even equiped with Onstar, then i bought the temp probe for another $10 shipped, and removed the stock rear view mirror, pop the GM mirror in, and ran the wire Positive to iginition ON under steering column, Negative ground to body frame, then mount the temp sensor at front bumper cover.
auto dim mirror only work when ignition key is ON, and works fine, best $55 i ever spent.
bronzemaxell
Postby DrLove » Wed Oct 17, 2007 12:41 pm
My Solara 99 has the auto-dimmer mirror but no cable is goint there. Since I put a LEd scanner, now I have a 12V and ground near the mirror. I see a buch of pins for the socket. I only need the 12V and ground there? what is the rights pins to connect there? My mirror looks like a OEM mirror, not one from another car..
thanks for your help.
Mazda 6 2010 6 speed black GS
DrLove
Postby Ruski » Wed Oct 17, 2007 12:53 pm
Ill take pics of the pins and ill post pics tonight for you ^^
Postby DrLove » Wed Oct 17, 2007 6:09 pm
Thank you Ruskimafia, I will be waiting your pics!
It will be very useful at night when a car is behind me with his HID who blind me.
DrLove
Postby Ruski » Wed Oct 17, 2007 6:09 pm
i jsut got home im going to take pics now
Postby Ruski » Wed Oct 17, 2007 6:23 pm
Here the plug
Wire with the red strip is positive .. its the first one on the mirror on your right
Here the mirror plug
I wired mine to the cig lighter , best and easy way to reach it.. and then grounded to the frame ...
Postby DrLove » Fri Oct 19, 2007 5:07 am
Thank you very much Ruskimafia for the pics!!
Where did you buy the plug? I have the mirror but not plug, I can solder it but it would look not so great!
I'm gonna call Toyota to know the price of this plug..
I guess it cost a lot.
Last time I buy there it was to change my rear emblems, the "Solara" was $40 and the "cowboy" was $30.
Now it looks awsome compare to the "peel" emblems that were on the car and it makes to car looks younger also.
DrLove
Postby Ruski » Fri Oct 19, 2007 8:55 am
haha.. um mine came with the plug i got it off a friends 04 maxima ..just solder them
Postby DrLove » Fri Oct 19, 2007 10:14 am
It don't seems to have an "universal" plug for the mirror.. so I don't want to pay a lot for a little plastic plug, I'm gonna solder it and use the ground and 12V from my led scanner already there on the mirror.
Thanks for your help buddy!
DrLove
Postby Ruski » Fri Oct 19, 2007 11:07 am
No problem .. or go to radio shack and they might have pplugs you can use for the prongs in the mirror
Users browsing this forum: No registered users and 74 guests
