SolaraGuy.com • View topic - instrument cluster questions
Postby superwhite06 » Mon Oct 08, 2007 3:34 pm
Hey guys, I got a few questions about the gauge cluster in a 2001 Toyota Solara 4cyl auto.
I was trying to change the cluster from green to blue using a transparent blue vinyl, so I had to remove the needles in order to get the vinyl on the back of the gauges. Well, long story short, I put the needles on and now I don't think the fuel gauge needle is working properly, I filled the tank up and the needled stayed at below 3/4 of a tank and didn't move after the tank was filled. What could be the problem??
Also, could I just swap a gauge cluster in there that I found on Ebay?? or is the mileage stored in the cluster??
Thanks for the help!!
superwhite06
Postby QuickSEV6 » Mon Oct 08, 2007 3:36 pm
http://www.blackcatcustom.com/
If you change clusters, the mileage is stored on the ECU. You'll have to take it to the dealer to reset the clust to show the actual mileage. The cluster just keeps an on-going total.
Postby superwhite06 » Mon Oct 08, 2007 3:41 pm
But if it is stored in the ECU would it just show up on the new cluster?? If it was stored in the cluster itself, then I would have to bring it ot the dealer to have them change it, right?
That was my understanding from another website. I might be wrong.
superwhite06
Postby QuickSEV6 » Mon Oct 08, 2007 3:44 pm
superwhite06 wrote:But if it is stored in the ECU would it just show up on the new cluster?? If it was stored in the cluster itself, then I would have to bring it ot the dealer to have them change it, right?
It is stored in both.
You'll NEED to take it to the dealer (or anybody else with the right tools and knowhow) to update your new cluster.
Just by pluging it in will not automatically update the cluster.
Postby superwhite06 » Mon Oct 08, 2007 3:45 pm
ok, thanks for the quick replies.
Does anyone know how this is done?? Ids it done with a computer? or OBD2?
superwhite06
Postby xet » Mon Oct 08, 2007 6:29 pm
try filling up and reseting the fuel needle to the top and see if it works
1998 camry xle
2005 g35 coupe 6mt
xet
Postby superwhite06 » Tue Oct 09, 2007 2:35 am
that didnt work I tried. but thanks.
superwhite06
Postby akora12 » Tue Oct 09, 2007 6:28 am
Is resetting the odometer possible with the older analog counters? I would assume the car still has a memory on the ecu, whether the cluster is digital or not.
Postby NeFaRiOuS_SLE » Wed Oct 10, 2007 5:41 pm
FYI: No Solara has an analog odometer, but you're right the readings are stored both ways... At least my friend's Volvo did.
Re: instrument cluster questions
Postby Kenz » Wed Oct 10, 2007 6:32 pm
superwhite06 wrote:Hey guys, I got a few questions about the gauge cluster in a 2001 Toyota Solara 4cyl auto. I had to remove the needles in order to get the vinyl on the back of the gauges.
Why don't you just get different color bulbs? Unless you want to change the color of the gauge needles there no reason to take them off.
- Mack
Silver `03 i4 5 Speed
Dropped w/ Tein & KYB
OBX Cat Back
Kenz
Postby Ruski » Wed Oct 10, 2007 6:36 pm
its a little late for that suggestion . he already messed the needles proper position .
Postby akora12 » Thu Oct 11, 2007 2:52 pm
NeFaRiOuS_SLE wrote:FYI: No Solara has an analog odometer, but you're right the readings are stored both ways... At least my friend's Volvo did.
Yeah, I was referring to my accord beater car. The odo stopped working a while back and I had to replace the cluster. I've never updated the odo b/c I wasn't sure if the mileage was stored on the ecu with an analog odo.
Users browsing this forum: Google [Bot] and 33 guests
