SolaraGuy.com • View topic - CEL came on randomly
Postby Solara_916/619 » Wed Oct 10, 2007 6:29 pm
hey just wondering if anyone knew about codes PO446 and PO773. My car was fine this morning, went to school, then started my car after school and the CEL came on. I took it to autozone and got those codes. Any help or suggestions?
2001 Silverstream Opalescent SLE
Solara_916/619
Postby Ruski » Wed Oct 10, 2007 6:31 pm
Postby Solara_916/619 » Wed Oct 10, 2007 6:36 pm
thanks, so do you guys know if P0446 (Evaporative Emission Control System Vent Control Circuit Malfunction) and P0773 (Shift Solenoid "E" Electrical) are serious issues?
Solara_916/619
Postby Ruski » Wed Oct 10, 2007 6:52 pm
well did you clear the codes ?? If no . do it remove your battery terminal. drive around and see if it comes back ..
Postby Solara_916/619 » Wed Oct 10, 2007 6:54 pm
can i just clear them like that? dont i have to get them fixed first? sorry ive just never had my CEL come on before so im not sure what to do
Solara_916/619
Postby Midias » Wed Oct 10, 2007 6:59 pm
P0446 means charcoal canister or valve on the canister
Postby Ruski » Wed Oct 10, 2007 7:03 pm
yes clear them, and see if it comes back.. i had p0446 on my solara for almost 3 years and never bothered getting it fixed . but it was a random code ..
Postby Solara_916/619 » Wed Oct 10, 2007 7:10 pm
ok but i have two codes, so im gonna try and clear them and see which one still shows up, thanks for the help so far
Solara_916/619
Postby Solara_916/619 » Wed Oct 10, 2007 7:16 pm
anybody know anything about the other code? the P0773 solenoid shift malfunction?
Solara_916/619
Postby Midias » Wed Oct 10, 2007 7:27 pm
Solara_916/619 wrote:anybody know anything about the other code? the P0773 solenoid shift malfunction?
The shift solenoid "E" is the solenoid that locks the torque converter at cruising speeds, in most cases solenoids are not the problem, they get clogged with foreign material and stop passing fluid or get stuck, I would recommend removing the transmission oil pan and inspect it for any metal particles in the bottom of the pan and if there are, the transmission is the problem and it will need to be replaced.
Postby Solara_916/619 » Wed Oct 10, 2007 7:31 pm
yikes, i hope i would not have to replace my transmission, that would be a nasty problem. I guess im gonna go ahead and check these issues out tomoro
and thanks ruskimafia and midias for you guys help!!
Solara_916/619
Postby Midias » Wed Oct 10, 2007 8:11 pm
When I had p0446 it only came on in the summer so I had my car inspected in the winter.
Postby bronzemaxell » Thu Oct 11, 2007 6:04 am
my 97 camry 2.2L has the P0773 code, along with P1133, P1135.
one is a transmission solenoid E electrical code,
one is a Air/Fuel Ratio sensor code,
i've tried to drain and refill ATF 4 or 5 times, the transmission still seem to shift a little bit rough, then until i replaced the A/F sensor, reset codes, nothing coming back now, i think the A/F sensor malfunctioned, engine lost power, and shifting late, causing the P0773.
hard to believe, but a new A/F sensor fix my P0773 error.
i would just reset the code, see if it will come back.
bronzemaxell
Users browsing this forum: Google [Bot] and 33 guests
