SolaraGuy.com • View topic - High Idle
High Idle
High Idle
Postby Jakecallun20 » Mon Oct 15, 2007 8:35 pm
Anyone have this problem? I start my engine and it jumps up to 2000 and then sits pretty at 1850..... but when I put it in gear it leaps down to 900-1kish. Is this normal? Anything I could adjust to make it idle lower at around 1100ish (avg idle rate right?) Thanks. Any help is appreciated.
umm
Postby rewmomi » Mon Oct 15, 2007 8:47 pm
mine idles around 1500 at most in the morning depending on how cold it is i think lol cuz when its really cold outside my car idles around 1500 but when it worms up for a few seconds its good goes down below 1000
rewmomi
Postby woa_its_j3ff » Mon Oct 15, 2007 8:56 pm
I have that. engine is cold. always does that, after a lil bit it goes back down. i think its normal.
Postby NeFaRiOuS_SLE » Tue Oct 16, 2007 9:51 am
Yeah, it's just a substitute for heated catalytic converters (e.g. the kind where there's a heating element integrated into it, but no there's none available and a waste of money to actually get it), since it is only effective when warmed up. Same thing happens to me.
Postby DrLove » Sat Oct 20, 2007 3:13 pm
Oh great Im not the nly one who have an idle of 1400 when it's cold outside, Iw as a little bit anxious that the car needs repair, I got my car few weeks ago and it was more warm now it's cold here in canada.
Thanks for the post.
Mazda 6 2010 6 speed black GS
DrLove
Postby Somedude » Sat Oct 20, 2007 3:55 pm
on really cold days the rpm is a bit higher when I start the lara.
I lived in FL for 10 years so far and I feel like I am in summer season the whole time, hahahha. :lol:
I didn't know its already cold elsewhere.
Somedude
Postby Gadgetjq » Sat Oct 20, 2007 5:33 pm
Jake,
High idle is normal when an engine is cold but 2000 is a bit high.
Something to check (especially if you're at fairly high mileage and have never done it). Take a look inside the throttle body. Open the butterfly manually and with a flashlight look for a ring of carbon where the butterfly contacts the bore.
If you see carbon, clean it out with (your choice) a toothbrush or Q-Tip and any kind of spray carb or FI cleaner.
What frequently happens is that carbon ring (that should be part of the regular maintenance schedule but isn't) can hold the butterfly open just a bit so the cold idle valve can't do its job.
Your rpm falls back to around 1000 just because the transmission is sucking off enough power to force the rpm lower.
Anyway, check the throttle body, clean it and see if that fixes your problem.
Cheers :cheers:
Gadgetjq
Postby Jakecallun20 » Sat Oct 20, 2007 9:03 pm
Gadgetjq wrote:Jake,
Cheers :cheers:
Alright, I'll do that thanks. I have never done that before so that will probably help. Mileage is 139151.
Postby Americanctm10 » Sat Oct 20, 2007 9:34 pm
here this should help.
http://solaraguy.org/viewtopic.php?t=33791&highlight=throttle+body
cleaning it does help idle.
Americanctm10
Postby Jakecallun20 » Sat Oct 20, 2007 9:50 pm
Americanctm10 wrote:here this should help.
Alright, Thx. That post said not to use carb cleaner. Thats what I have that will mess something up?
