SolaraGuy.com • View topic - please help out
please help out
please help out
Postby solara86 » Wed Oct 17, 2007 11:56 pm
so solara has been messing up lately like i think it is the wiring or something like the hand brake light keeps on coming on when it isnt even being used what should i do...and then my clock quit working and my 12v plug socket quit working too...like how do i fix that...and any solaras out there in san antono tx or austin
solara86
Postby Turbosolara » Thu Oct 18, 2007 12:05 am
what did you do to your car before all those problem? you just need to replace your fuses, but there is something wrong that cause those fuses went out
Postby Chinky420 » Thu Oct 18, 2007 11:46 am
^^ x2, while the CEL didn't come on, you may be able to pull some codes out if there are indicator lights coming on...i'd goto an autozone when the lights are on, and see if they can get any problem codes out of your car, which will give you a better idea of what the problem is.
<-- san antonian, by the way.
Chinky420
Postby nemoxfishy » Thu Oct 18, 2007 8:02 pm
i have a similar problem...everything is fine except for my handbrake light. it wouldn't go off after a cold start then after a lil while, 2 or 3 mins ... it goes off and its back to normal agen. weird eh?
nemoxfishy
Postby geminimouse » Thu Oct 18, 2007 10:06 pm
the brake light is on because your brake fluid is low, which is also an indicator that u might need ur brakes serviced. Add a little brake fluid into the reservoir to make that light go away.
for the other problems, u'll need to check the manual to see which fuses those go to or just take it to a shop.
08 Accord Coupe
99 Solara Sold on 7/7/07
geminimouse
Postby Turbosolara » Thu Oct 18, 2007 10:10 pm
geminimouse wrote:the brake light is on because your brake fluid is low, which is also an indicator that u might need ur brakes serviced
not simply replace the pad or rotor. it is an indication of there is not enough pressure inside your power brake system.
Postby solara86 » Mon Oct 22, 2007 2:44 am
thanks...so much..will get that checked..and get my solara bak to normal
solara86
sO WHAT MADE THAT HAPPEN???
Postby ClearWater » Wed Oct 31, 2007 2:34 pm
I have the convertible 2003. First the interior light went. So I thought it was just a bulb. Now the clock is off and the cigarette lighter too.
So I checked the fuses behind the coin tray thingy. Its fine. No real work has ever been done except a oil leak in the engine that the dealer did covered by warranty and I had the trans fluid changed just because.
What could be wrong? The car has 54,000 miles and is garage kept. The dealer told me that the fuses never blow, that it might be something else. So, ok, I don't trust the dealer. They'll tell a girl anything for a buck.
Any suggestions?
ClearWater
Re: sO WHAT MADE THAT HAPPEN???
Postby pythonjosh » Sat Nov 03, 2007 9:34 am
ClearWater wrote:I have the convertible 2003. First the interior light went. So I thought it was just a bulb. Now the clock is off and the cigarette lighter too.
Any suggestions?
I wouldn't listen to anybody that says fuses never blow, that's their soul purpose in life lol. Get behind the kick panel to investigate further. Check wires, plugs, and fuses. Or take a very detailed pic down there and post it.
pythonjosh
Postby Turbosolara » Sat Nov 03, 2007 9:37 am
Any suggestions?
maybe you checked wrong fuse, go check the fuse and report the number and hopefully people here can help you out.
