SolaraGuy.com • View topic - Grill removal question..
Postby socalisolara » Fri Oct 19, 2007 1:21 am
i have 2000 solara and yesterday i was trying to remove the grill with no luck. I removed the top bolts so far but than i have no idea how to remove the grill. Help please.
socalisolara
Postby woa_its_j3ff » Fri Oct 19, 2007 6:23 am
there's tabs/clips (About an inch in size). i used a screw driver to press them up/down (dont remember which one) then pulled out with some little force. good luck.
Postby akora12 » Fri Oct 19, 2007 6:30 am
The tabs/clips attach directly to the front bumper. If you get under them with a screwdriver and twist, they should disengage. It helps to start at one corner and work your way to the other side. Just make sure you don't let the side you already unclipped go back together.
Users browsing this forum: Google [Bot] and 33 guests
