SolaraGuy.com • View topic - whats a rotor?
whats a rotor?
whats a rotor?
Postby rewmomi » Mon Oct 22, 2007 12:54 pm
lol anyways i am about to change my brakepads but never really messed with brakes before any thing i should know if i encounter a problem half way? Oh i know what a rotor is lol
rewmomi
Postby Sebas007 » Mon Oct 22, 2007 1:11 pm
Nothing complicated if you don't unplug brake hoses. Just be sure that you install your pads on the good way. Yeah yeah...I already did a dumb error and I installed 1 pad on the wrong side !!! :evil: I had to buy a brand new set for the whole front brakes...just don't do that error too by going too quickly.
Postby Chinky420 » Mon Oct 22, 2007 2:42 pm
this is also a good time to paint the caliper if you wanted to do so.
but be sure to have time to clean the caliper, and allow time for the paint to cure....which means don't do this if you have to drive your car tomarrow.
Chinky420
Postby rewmomi » Tue Oct 23, 2007 2:18 pm
Chinky420 wrote:this is also a good time to paint the caliper if you wanted to do so.
nice I wanted to get some new brakes because my brake light came on so i found some hawks on ebay i also found drill slotted rotors with no namebrand but they look nice. What u think about upgrading the two?
rewmomi
Postby Midias » Tue Oct 23, 2007 2:30 pm
Don't bother with drilled and slotted unless you are on the track just get brembo blanks it will give you better stopping power.
Postby rewmomi » Tue Oct 23, 2007 2:36 pm
Midias wrote:Don't bother with drilled and slotted unless you are on the track just get brembo blanks it will give you better stopping power.
And you get these from where exactly?
rewmomi
Postby rollaevo99 » Tue Oct 23, 2007 2:37 pm
Postby nammby77 » Tue Oct 23, 2007 2:38 pm
http://www.tirerack.com/brakes/results. ... and=Brembo
nammby77
Postby nammby77 » Tue Oct 23, 2007 2:39 pm
Oops too late.
nammby77
Postby Solorange » Tue Oct 23, 2007 4:16 pm
I also heard to stick with Stock Toyota pads too. Hawks are good pads but apparently base on SG experience the stock pads still work the best.
Postby Midias » Tue Oct 23, 2007 5:38 pm
Solorange wrote:I also heard to stick with Stock Toyota pads too. Hawks are good pads but apparently base on SG experience the stock pads still work the best.
Stock Toyota are an awesome ceramic blend and work great. Personally I use bendex ceramic from advance auto parts because they give me free sets for life.
Postby Sebas007 » Tue Oct 23, 2007 6:02 pm
I personaly chnage my rotors + pads + painting my calipers (black) + install my StopTech SS brake lines at the same time.
For the painting purpose I used VHT calipers painting and I follow their instructions...I put the painted calipers parts in the oven at a low temp (like they said) and it gives a great finish that last for pretty long...they still seems to be painted since shortly.
Postby Ruski » Tue Oct 23, 2007 7:03 pm
VHT caliper paint is Great.. I used it as well on my calipers
Postby Solorange » Tue Oct 23, 2007 8:12 pm
I like stock pads because they work and they dont have any break dust
