SolaraGuy.com • View topic - hood shakes
hood shakes
hood shakes
Postby rewmomi » Mon Oct 22, 2007 1:41 pm
i have noticed recently that my hood shakes when im driving faster than usuall do u know what is causeing it to shake? i check a million times to see if my hood was popped but it was not so yeah
rewmomi
Postby SolaraBlue » Mon Oct 22, 2007 2:29 pm
most likely vibrations from the engine... do you drive a v6 or 4 cylinder? does your hood feel loose when you pop it open? i.e. does it move from side to side easily?
Postby TMMK Toy » Mon Oct 22, 2007 2:49 pm
May be the latch needs adjusting or replaced? Have you hit anything lately? When I kissed a semi tire it cracked my lower bumper but also messed up the latch. It latches but at high speeds it noticeably shakes and when I pull up on it it has a bit of play when before there was none. So I'm gonna get a new latch mechanism
TMMK Toy
Postby rewmomi » Tue Oct 23, 2007 2:15 pm
SolaraBlue wrote:most likely vibrations from the engine... do you drive a v6 or 4 cylinder? does your hood feel loose when you pop it open? i.e. does it move from side to side easily?
iT IS A V6 AND NOT REALLY IT IS MISSING A HOOD DAMPER THOUGH ON THE LEFT SIDE DO U THINK IT COULD BE THAT?
rewmomi
Postby rewmomi » Tue Oct 23, 2007 2:16 pm
TMMK Toy wrote:May be the latch needs adjusting or replaced? Have you hit anything lately? When I kissed a semi tire it cracked my lower bumper but also messed up the latch. It latches but at high speeds it noticeably shakes and when I pull up on it it has a bit of play when before there was none. So I'm gonna get a new latch mechanism
that might be it i have hit something awhile ago not serious but it could be that ill look into it thanks man
rewmomi
Postby TMMK Toy » Sun Nov 04, 2007 10:18 am
Wanted to bring this back up. Ended up not needing a new latch. My friend noticed my hood was slightly loose after he shut it yesterday and I told him it was the latch from that tire. Well, he made me feel like a dumbass. There are rubber stoppers on each side of the engine bay along the frame rails that you can turn left or right to raise or lower. He raised em up a bit and now the fit is back to factory. I was very happy.
TMMK Toy
