SolaraGuy.com • View topic - Tune ups
Tune ups
Tune ups
Postby Grnarowana » Tue Oct 30, 2007 12:39 pm
Since I'm changing my brake pads and my car is almost 120K. I'm thinking about a light tune up, but looking for the cost, and I don't want to get fooled by a mechanic. Can you guys help me out?
Tune up on a V6 1999 Manual Solara:
Oil Change
Brake Pads
Spark Plugs
Maybe Transmission and brake fluid
Replace Coolant
Basicially a 120K tune up reccomened by toyota owner's manual
Grnarowana
Postby unbalancedwood » Tue Oct 30, 2007 1:05 pm
DIY Costs:
oil - $17
Pads (all corners) - $100-120 Toyota OEM
Rotors (all corners) - $150 Brembo Blanks
Transmission flush - $100 (depending on what you need, if youve already got a flush before then you just have to drain and refil 3.5qts. If not your gonna have to take it in to get serviced)
Spark Plugs - $35-40 Denso Double Platinum or NGK (ebay)
Coolant - $15 (two jugs of Prestone Orange) tutorial section.
Where do you live?
unbalancedwood
Postby LatinUSMC » Tue Oct 30, 2007 3:56 pm
drive belts and timing belt replacement are important...
LatinUSMC
Postby Americanctm10 » Tue Oct 30, 2007 4:08 pm
LatinUSMC wrote:drive belts and timing belt replacement are important...
yea definitely. Timing belt should be replaced at about 100k, also replace your water pump.
Americanctm10
Postby Grnarowana » Tue Oct 30, 2007 5:23 pm
waterpump and timing belt already done. I live in San Francisco, but go to school in Santa Barbara. so if i do all that, roughly 600-700?
Grnarowana
Postby unbalancedwood » Tue Oct 30, 2007 6:14 pm
no man, about 350$ total
unbalancedwood
