SolaraGuy.com • View topic - debadging
debadging
debadging
Postby Stark33 » Wed Oct 31, 2007 10:09 am
i have debadged my previous cars but i dont want to mess up on this one whats the best way to do it? what do i need?
No emblems
Slammed on tsw's
customs intake and exhaust
black grill black windows
Stark33
Postby Ruski » Wed Oct 31, 2007 10:17 am
Best way is to SEARCH.....
Postby Gangis » Wed Oct 31, 2007 10:18 am
I recently did a partial debadge of my car. I used a hairdryer to soften up the adhesive and then a old plastic comb to separate the badge from the car. Next, I hit it with some extra strength Acetone to remove the remnants. Works a treat. check out the pics:
http://www.solaraguy.org/viewtopic.php?t=36395
Gangis
Postby unbalancedwood » Wed Oct 31, 2007 10:28 am
search.
soft floss, and goo gone. like gangis said a hot day will help get it off. there are no holes for the gen 1s
unbalancedwood
Postby Gangis » Wed Oct 31, 2007 10:30 am
Goo Gone didn't help me very much. In fact, it just made the remnants all orange. Acetone definitely did the job, though.
Gangis
Postby unbalancedwood » Wed Oct 31, 2007 11:34 am
^ ill have to try, i can still [kinda] see the outline of the letters.
unbalancedwood
Postby Ruski » Wed Oct 31, 2007 11:51 am
Acetone Is bad for your paint... goo gone works and a hair drier.. i still saw the outline on my car as well. and then i clay bared it helped
Postby Gangis » Wed Oct 31, 2007 12:16 pm
That's why you wash the acetone off right after it does its job. :) It's been over a week now and the paint looks GREAT!
That outline is partially due to the paint fading because of the sun, not too much you can do about it but the clay bar DOES help a bit.
Gangis
Postby unbalancedwood » Wed Oct 31, 2007 12:21 pm
then alright, what Ruski said.
I used goo and clay bar and I have a little of an outline, partly cause i have a dark car i suppose.
unbalancedwood
Postby Solara_916/619 » Wed Oct 31, 2007 1:39 pm
you can use some paint cleaner or a not too strong rubbing compound that will get rid of those outlines after you debadge
2001 Silverstream Opalescent SLE
Solara_916/619
Postby redgen1 » Wed Oct 31, 2007 2:10 pm
my friend used to detail cars, hes gonna wet sand the lines and blend it all in the spring for me
02 SLE V6
Kaizen *constant improvement*
redgen1
Postby Solorange » Wed Oct 31, 2007 4:15 pm
I got the reminisces off with car wax. I wouldn't trust acetone either.
Postby pearlydiamondwhite » Wed Oct 31, 2007 8:15 pm
use heat, a plastic body filler spreader (any parts store just about carries them), roll the adhesive off with your thumb, wait til its warm and not hot (you could buy an eraser wheel that will fit a drill and take off the double sided tape, be careful though, if you sit in one spot too long it will burn through the paint). 3M makes an adhesive remover that will take off the residue and what ever else you didnt get with your thumb.
Diamond White...for more horepower
pearlydiamondwhite
Postby Americanctm10 » Wed Oct 31, 2007 8:45 pm
Gangis wrote:Goo Gone didn't help me very much. In fact, it just made the remnants all orange. Acetone definitely did the job, though.
Really? Goo Gone worked perfect for me. I used a 35lb fishing line with a hair dryer and it worked great. Then i clay bared and waxed over the areas.
Americanctm10
Postby SolaraBlue » Wed Oct 31, 2007 9:53 pm
pearlydiamondwhite wrote:use heat, a plastic body filler spreader (any parts store just about carries them), roll the adhesive off with your thumb, wait til its warm and not hot (you could buy an eraser wheel that will fit a drill and take off the double sided tape, be careful though, if you sit in one spot too long it will burn through the paint). 3M makes an adhesive remover that will take off the residue and what ever else you didnt get with your thumb.
dont listen to this guy^^^^^ :lol:
like everyone else says... ALL you need is a hair dryer, floss (or fishing line) and goo-gone or any other adhesive remover... a quick wax over the spot the emblems were will get rid of any outlines.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 15 guests
