SolaraGuy.com • View topic - Rear Suspension Noise...PLZ HELP
Postby solaran » Wed Oct 31, 2007 3:19 pm
guys i have been experiencing loud noise from rear right or may be both sides of rear suspension. its 1999 SLE. Can you guys help me solve this problem. its sound like rattling or something lose even over little bumps. If its any part i need plz specify what part it is exactly so i can purchase it online or if you guys can mention a resonable website. Thanks a lot.
p.s: can you guys specify how to get TSB, like detail on fixing issues mentioned?
THANKS
solaran
Postby AllShowNoGo » Wed Oct 31, 2007 3:20 pm
check sway bar links
AllShowNoGo
Postby ---CAMRAZY--- » Wed Oct 31, 2007 3:47 pm
Actually, sounds like the Struts are blown. How many miles are on your car and have you ever had the struts replaced?
Postby jrzymuscle23 » Wed Oct 31, 2007 4:00 pm
Two things- Rear Struts need to be replaced- and your rear strut mounts are probably shot- if your car sounds like its falling apart- its probably that.. ;)
jrzymuscle23
Postby akora12 » Wed Oct 31, 2007 4:49 pm
The rear strut mounts don't have bearings so it would be more likely the struts are bad.
Postby unbalancedwood » Wed Oct 31, 2007 4:50 pm
whats your location, ive got stock rear struts 12k on them...
unbalancedwood
rear noise
Postby solaran » Wed Oct 31, 2007 5:38 pm
car has 146,000 miles but rear struts have reacently been changed abt 1000 miles from the guy i bought it. what are struts mounts? could they be doing it? or stabilizer bar bushings?
solaran
Postby Ruski » Wed Oct 31, 2007 6:24 pm
IF you just recently got them replaced then its the top strut mount bolt that wasn't tightened down to proper specs. I had the same problem before replacing my suspension
Postby jon015 » Wed Oct 31, 2007 6:46 pm
most likely its your strut mounts, had same issue, rattling over every bump, and clanging like something is loose. replaced the mounts, problem solved.
jon015
Postby jrzymuscle23 » Wed Oct 31, 2007 7:36 pm
Yup- like I said - rear strut mounts- I purchased some KYB and they've been great. Also, like said before- make sure everything is tightened down correctly! if you need a place to buy the parts- I got mine from rockauto.com .. Great place- I've actually been buyin everything there....
jrzymuscle23
Postby solaran » Thu Nov 01, 2007 11:04 am
Thanks guys for gr8 help soonest i get a chance will get them checked and replace as needed.
Thanks
solaran
Postby DrLove » Fri Nov 02, 2007 10:53 am
:o I got the same problem for 1 week now... I changed the bushing behind 2 months ago and all was ok..and now it is doing this big sound when I hit little bumps or big ones..people in the streets are almost turning heads...so much shame..lol...I will go to the garage next week to see what's going on.. Also a little sound from the wheels... a little "ishh ... ishhhh...ishhh" when the wheels are turning, seems to be from behind also..
gosh I spent $1000 2 months ago to replace the radiator,bushing, and other stufs that I dont even know what it is...
Im gonna go see that same agrage, I have a warranty of 6 months ..maybe it come from the same pieces..but it doesnt make the same noise then 2 months ago with the bushings..
Mazda 6 2010 6 speed black GS
DrLove
Postby jrzymuscle23 » Fri Nov 02, 2007 11:13 am
DrLove wrote::o I got the same problem for 1 week now... I changed the bushing behind 2 months ago and all was ok..and now it is doing this big sound when I hit little bumps or big ones..people in the streets are almost turning heads...so much shame..lol...I will go to the garage next week to see what's going on.. Also a little sound from the wheels... a little "ishh ... ishhhh...ishhh" when the wheels are turning, seems to be from behind also..
Let us know what happens- I'm curious to hear.. and pictures if possible..
jrzymuscle23
Postby DrLove » Sat Nov 03, 2007 7:45 am
Hi guys!
with a friend I found what was the problem!
there was 2 problems,
1st: the "ishh ishh" sound was from the left rear wheel.
It was the protection metal plate around (behind) the disc.
It was vibrating on the disc and was doing this cheap rust metal noise.
2nd: the big "boom" when I hit little bumps.. it was simply the E-brake cable from the left rear again. I knew that the E-brake isn't working on the car and I don't really care. But the cable is cut and it was hiting under the car and make sound.
I'm happy because it cost me 0$ and my car is now like before.
3 "tie rap" for the E-brake and some muscle to remove the plate.
DrLove
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 16 guests
