SolaraGuy.com • View topic - Changing the rear ABS Sensor... Is it a DIY?
Postby kaarona1 » Mon Nov 05, 2007 11:07 am
I have the ABS light on in my 99 SLE. The jerk off mechanic broke it when changing rear struts, but he is not replacing it. That battle is over. My question is can I change it myself? And does anyone have a diagram of how?
Thanks!
kaarona1
Postby AllShowNoGo » Mon Nov 05, 2007 11:32 am
Same thing happened to me and i am just about to get my abs sensor done aswell
Very big pain in the ass to get out cause theres soo much dirt holding it in.
Had to break mine out in pieces with a needle nose.
This part is very expensive, plus i had no luck finding a aftermarket replacement.
The abs sensor is the grey plastic pieace attached behind the rotor, and the wire goes somewhere into the back seat
AllShowNoGo
Postby SleeperSolara » Mon Nov 05, 2007 1:10 pm
It's not really that hard to change the rear ABS sensor.
Postby kaarona1 » Mon Nov 05, 2007 1:18 pm
SleeperSolara - Thank you for that very detailed response. Any chance you would like to provide some insight on how to go about it? Maybe provide some suggestions and add to the valuable insight that you have already provided...."It's not really that hard to change the rear ABS sensor."
Thanks!
kaarona1
Postby 1st Gen Sol » Mon Nov 05, 2007 2:58 pm
You have to remove the bottom half of the backseat to get to the ABS sensors.
When you remove the rear, you'll see a black cable running from the inside to the outside.....its held in by a rubber plug that you'll have to just pop off. From there you can pull it out from the outside....you'll also have to remove the rear wheels as well.
The outside portion of the ABS sensor is connected to the strut, held in by one bolt and a clip the holds it in place.
To install the new ABS sensor, just do the opposite of how you just uninstalled the bad one.
Price for a new ABS sensor is somewhere along the lines of $130 to $175 from the dealer...can't remember the exact price b/c its been so long ago that I had to do mine.
.......hope this helps you out.
1st Gen Sol
Stock Sleeper
Stock Sleeper
Postby SleeperSolara » Mon Nov 05, 2007 3:56 pm
kaarona1 wrote:SleeperSolara - Thank you for that very detailed response. Any chance you would like to provide some insight on how to go about it? Maybe provide some suggestions and add to the valuable insight that you have already provided...."It's not really that hard to change the rear ABS sensor."
Thanks!
Sorry about that response.
"1st Gen Sol" put in a very good way.
Remember when you unbolt the ABS sensor be very careful.
Postby kaarona1 » Tue Nov 06, 2007 5:59 am
Thanks guys! That should go in the DIY section.. Thats why I love Solarguy!
kaarona1
Postby kaarona1 » Tue Nov 06, 2007 11:43 am
Sweet - just got a used ABS sensor for $45 shipped with a 90 day warranty. I will change it when I change my rims for winter. It actually started to snow in Indiana today!
kaarona1
Postby bronzemaxell » Tue Nov 06, 2007 1:08 pm
when i replaced mine, it was front passenger side, having a very hard time removing the old one, twist, turn, pull, wd-40, liquid wrench, nothing work, because it was fused into the hole, even thought the service manual instruct to remove the 10mm bolt, then pull it out.
so i broke off the old one, bad anyway, use a drill and drill out the remaining, and file off all the rust around the hole cylinder wall before a new one will fit in.
bronzemaxell
Postby kaarona1 » Wed Nov 28, 2007 6:20 am
OK- So I changed the rims back to stock for the winter and replaced the R.R. ABS Sensor... What a pain in the D$CK getting the old one out ! (as Bronzemaxell said). I broke every piece off the side and it had to be in 10 pieced before I got it all out. Even getting the new one in was almost impossible. Anyway, after resetting the ABS computer, the light came back on in 2 minutes with the same code (3 flashes pause 3 flashes = right rear ABS Sensor). Anyone have any other thoughts other than the new sensor is bad (it could be since it was used and they are sending another), but any additional suggestions?
kaarona1
Postby AllShowNoGo » Wed Nov 28, 2007 7:27 am
crappy i have to do the same process soon talk to sleepersolara. he told me if i replace mine and it doesnt fix the problem it could be something else, forgot what he said.
Hopefully its just a bad abs sensor
AllShowNoGo
Postby SleeperSolara » Wed Nov 28, 2007 12:24 pm
"kaarona1" Yeah it could be the ABS unit actuator....
Where did you get your ABS sensor from??
"AllShowNoGo" Yeah i had gotten a wrecked Solara ABS sensor at the salvage yard, and replaced my OEM one for the wrecked Soalra ABS sensor and i still had the light on....
Well when i got my A/C fixed i had to get a new brake master cylinder and the guy checked my ABS light also.
He said my ABS actuator is messed up.
The valve or somethin' in the ABS actuator unit for the rear wheel [which eva threw the code] is messed up. So the only way to fix it is to replace the whole ABS unit....
Postby kaarona1 » Wed Nov 28, 2007 1:16 pm
Is the ABS Actuater the ABS Computer? Or somthing else? Thanks!
SleeperSolara wrote:"kaarona1" Yeah it could be the ABS unit actuator....
kaarona1
Postby kaarona1 » Wed Nov 28, 2007 2:00 pm
OK - I found the Actuator/Pump. Anyone have experience replacing this part? Any tips or suggestions? Thanks
kaarona1
Postby AllShowNoGo » Wed Nov 28, 2007 2:39 pm
how much did the part cost and what would cause this part to fail. My abs light came after a crappy suspension install so i hope this not the case.
AllShowNoGo
