SolaraGuy.com • View topic - im pretty sure this might be it.. confirm?
Postby woa_its_j3ff » Mon Nov 05, 2007 10:24 pm
I know my car pulls to the right a bit... when i drive..
now sometimes if I brake, and my hand isnt on the wheels, my car will pretty much turn by itself very very had to the right.
is this because of my alignment issue? and will fixing it solve this problem?
just want ot make sure, thanks!
Postby trdkamuri51o » Mon Nov 05, 2007 10:25 pm
praly alignment issue.. could be a siezed rotor too
trdkamuri51o
Postby SleeperSolara » Mon Nov 05, 2007 10:27 pm
Yeah it could be the alignment.
1. Or it could be the tires, if the air pressure isn't right.
2. Or that the tread of one tire isn't the same wit the other tire.
3. Or is the could be the tires don't match left and right.
It's either one of those 4 choices i just listed.
If one of the 3 number choices then that's not too bad.
If it's just an alignment then get an alignment.
Postby woa_its_j3ff » Mon Nov 05, 2007 10:30 pm
hrm well I have 2 differnet tires, but thats front n back. not left n right.. air pressures are just fine. i check them every week.. guess it's just alignment....
i have just had new rotors and pads put on a few months ago.. doubt it could be that, plus i just had my entire brake system checked a few days ago.
Postby SleeperSolara » Mon Nov 05, 2007 10:44 pm
woa_its_j3ff wrote:hrm well I have 2 differnet tires, but thats front n back. not left n right.. air pressures are just fine. i check them every week.. guess it's just alignment....
Oh, i see.
Yeah same here.
I have Michelin on the front 2 tires, and the rears have Falken.
Postby woa_its_j3ff » Mon Nov 05, 2007 10:48 pm
Dunlops front.
bridgetstones back.
Postby Eye8Pussies » Mon Nov 05, 2007 11:46 pm
trdkamuri51o wrote:praly alignment issue.. could be a siezed rotor too
I believe you mean a seized (or sticky) slider ;)
rotors don't seize, and if his caliper seized, then the brake will either not work at all and the car will do more than just pull, or always be on the rotor, and the car will again- always pull.
a seized slider will make the caliper still work, but not to its full potential, making a car pull a certain way when braking
Postby ---CAMRAZY--- » Tue Nov 06, 2007 2:57 pm
This kid recently lowered his car, and I know it's the alignment..... Just likes being dramatic like any other day here on the forum.
Postby Somedude » Tue Nov 06, 2007 3:03 pm
have the alignment process done by a local store.
My brother's Accord also veers to the right, my dad say the car's tires have not been balanced for a while and the alignment is a bit off.
Somedude
Postby Toy1mzfe » Tue Nov 06, 2007 3:10 pm
its probably your alignment. save ur tires and get an alignment. its much cheaper than tires.
Postby Ruski » Tue Nov 06, 2007 3:38 pm
---CAMRAZY--- wrote:This kid recently lowered his car, and I know it's the alignment..... Just likes being dramatic like any other day here on the forum.
:lol:..... yea Jeff its alignment
