SolaraGuy.com • View topic - Squeaky Drivers seatbelt
Postby 70weeks » Thu May 08, 2003 9:50 am
This is the only thing that makes noise in my car.
Anyone else have this problem?
70weeks
Postby NASTY » Thu May 08, 2003 9:51 am
nope
where does it sound like its coming from?
'01 SLE V6
NASTY
Postby Jackass-Jeff » Thu May 08, 2003 10:17 am
i get it once in a while, but not that often...
You know how out seatbelt top anchor is move-able? I think it's that... sometimes when I adjust the seatbelt, that thing moves back and forth and gets out of the "locked" position
1GR-FE ftw!
Jackass-Jeff
Postby 70weeks » Thu May 08, 2003 1:56 pm
Mine on the center console side, where the female end of the buckle moves back and forth against the side of the seat.
70weeks
Postby Guest » Thu May 08, 2003 2:33 pm
i get the squeaking sound from the female side near the center console too.
Guest
Postby Jaimster » Thu May 08, 2003 5:14 pm
Yeah, I get a squeak from the top belt too.
Jaimster
Postby krook » Thu May 08, 2003 6:48 pm
bust out some armor all and lube that sucker!
krook
Postby xyntax » Thu May 08, 2003 10:56 pm
Hit the headrest or back of your passenger seat and see if you get the same annoying squeek. I thought my squeek came from the door or seatbelt, but I found out it was the adjustment bar below the seat after someone here pointed it out.
I still dont know how to fix it. For now, I just adjust my seat back and forth and sometimes it goes away.
-~=| XYNTAX |=~-
2AZ-FE & 13B-MSP
xyntax
Postby Jai_Jai_Binks » Fri May 09, 2003 8:15 am
I have the EXACT same problem, squeek from the drivers side belt where the bucks mates with the clip. I have talked about this to a toyota mechanic, he said this if it was under warranty:
he would first lube the parts again (generously) and secure all bolts again to check them....However, i've done the same at home, it would great for a few months...but the squeek comes back! I've done it twice since i've bought my car (feb 2002). If we all report this together..could be get a tsb issued?
