SolaraGuy.com • View topic - Help needed with sunroof
Postby Jetfixer » Fri May 09, 2003 5:19 pm
I have a 99 SLE V6 with the sunroof. Does anyone have info on adjusting the sunroof panel? Here's what's happening; If I tilt the sunroof up, then put it down, the rear rubber edge rolls up and the panel won't go completely flat in the recess. Then if I try to run the roof rearward, it either won't move, or the rubber rolls until it snaps down with a nasty thump and then slides back. I've tried waxing the roof and putting silicone on the rubber. This helped a bit, but not much. How do I adjust the sunroof panel to close slightly further forward?
Jetfixer
