SolaraGuy.com • View topic - The power window doesn't work for the passenger now!!
Postby DrLove » Mon Nov 19, 2007 1:26 pm
Hi guys!
a pretty annoying problem here... the passenger power window stopped to work for about a week now, the driver side is still working.
I would like to know where is the fuse or relay for the power window? I try to see under th steering..I see lots of fuses but not with the name "windows" or something similar.. I saw that there is more fuse and relay under the hood...here again no "windows" name....
Somebody can help me? I would like to see if there is only a fuse or relay who is broken before to open the door panel..here in Canada it's a bit cold to work on the car and I don't want it broken all the winter..
:-? thanks..
Mazda 6 2010 6 speed black GS
DrLove
Postby DatSRBoi » Mon Nov 19, 2007 1:49 pm
Uhhh Did you turn off the button on the driver side to allow it to work on the passenger? Hehe I used to do that to myself allot.
Postby DrLove » Mon Nov 19, 2007 1:52 pm
No. The switch is no working on both side... the passenger and driver can't control the passenger window... only the driver window is working now..
DrLove
Postby DrLove » Mon Nov 19, 2007 6:19 pm
Somebody can help me on that?? :o
DrLove
Postby Dawgz » Mon Nov 19, 2007 6:55 pm
maybe ur regulator for the passenger window is dead?
Postby DrLove » Tue Nov 20, 2007 6:03 am
Ok..
Where can I found this passenger regulator on the car?
DrLove
Postby Dawgz » Tue Nov 20, 2007 9:17 am
DrLove wrote:Ok..
the regulator is the actual unit that the window slides up and down on, its a metal bracket with pulleys and a motor, and a mount which the window sits on.
Sometimes the plastics in the pulleys break or sometimes the motor in the regulator just dies....
Open up the door panel from the inside and then press the button, see if the motor tries to wind or watever. if the motor isnt working, look for broken pieces of plastic from the pulleys around the bottom of the door.
It could be this, or simple as a fuse.
Check both.
Postby DrLove » Tue Nov 20, 2007 5:45 pm
Thanks for your help Sawgz!
a last question, where can I found the fuse for he power window? or the relay? the exact place please... thanks!
DrLove
Postby Dawgz » Tue Nov 20, 2007 6:36 pm
DrLove wrote:Thanks for your help Sawgz!
im not really sure where that fuse is located, but u can check the box near the battery (the black plastic box that has all the fuses) or the fuse in back of that little container compartment that is located a bit to the left and bottom of the steering wheel column (inside the car)
