SolaraGuy.com • View topic - EGR VALVE..............
Postby mowke » Thu Nov 22, 2007 10:50 am
Been awhile since I've been on. First off, Happy Thanksgiving everybody. I've got an 00 w/auto 4cyl, 115k. The engine light came on the other day. I took it to Auto Zone to check the code. It said the EGR valve could be clogged or bad. I was going to just clean it and reinstall, until I broke BOTH of the 6mm mounting bolts. Turns out the valve was full of carbon. The bolts were so seized that I couldnt get them out w/an easy out. I got the new one installed and the check engine light came off. How common are the EGR valves to failure? I could definitely tell a big difference between the old and new as far the movement of the valve. Total cost w/easy out $180, ouch.
mowke
Re: EGR VALVE..............
Postby onefiend » Thu Nov 22, 2007 11:04 am
mowke wrote:Been awhile since I've been on. First off, Happy Thanksgiving everybody. I've got an 00 w/auto 4cyl, 115k. The engine light came on the other day. I took it to Auto Zone to check the code. It said the EGR valve could be clogged or bad. I was going to just clean it and reinstall, until I broke BOTH of the 6mm mounting bolts. Turns out the valve was full of carbon. The bolts were so seized that I couldnt get them out w/an easy out. I got the new one installed and the check engine light came off. How common are the EGR valves to failure? I could definitely tell a big difference between the old and new as far the movement of the valve. Total cost w/easy out $180, ouch.
I had the EGR problem on my 01 at 55,000 miles, took it to the dealer and they replaced the EGR valve and cleaned out the system, but CEL came back on at around 80,000 miles for the same problem :x
2007 Camry SE V6
onefiend
Postby Midias » Fri Nov 23, 2007 6:49 pm
never had a problem my self but if I do pb blaster will be my friend.
Postby SolaraBlue » Fri Nov 23, 2007 6:58 pm
think i paid a little over $200 to replace my egr... it went at about 60k miles...
Postby Midias » Fri Nov 23, 2007 10:43 pm
Damn I guess I am lucky at 150,000 miles
