SolaraGuy.com • View topic - What Bosch O2 sensor part number for code P0135?
Postby ringmasster1 » Mon Nov 26, 2007 9:49 am
After searching I know that CEL code P0135 is for my O2 sensor that is closest to the firewall but I am unsure which Bosch part number I should have. I bought part #13355....is that the right one?
I have a 1999 V6
1999 Solara - SLE V6
ringmasster1
Postby Chinky420 » Mon Nov 26, 2007 10:24 am
while i'm not exactly sure of part numbers, i'm pretty sure ppl here will need to know if your lara is cali-spec w/ the pre-cat's or not. if i'm not mistaken the cali-spec and non-cali spec use two different sensor combinations.
good luck with it though
Chinky420
Postby ringmasster1 » Mon Nov 26, 2007 2:31 pm
The car is not cali spec but i actually decided to let a shop do the job...it was surprisingly cheap and they are getting the part from toyota.
ringmasster1
